MarcG
I have seen it go from 75.7-9 to about 74.5 or something on my Norway trip. And it is back to 75.0-75.3 with 5-10C I hope I can get it back above 75.5 with 20C outside temp.
How are you measuring these kWh values?
The simple line drawn from start to finish is always a bit misleading. As recently as the 17,970 mile mark, you were at or above 310miles of range. Only after that, you've experienced a drop, which is in the last couple months. There's a strong chance it's correlated with temperature, but you'll only know that in the Spring.DP: May 2018 LR RWD with 18" aeros. TeslaFi reports 295mi for 100% charge. I never got the 325 mi rated range, max was 313mi. Hopefully all these DPs are attributed with colder climates.
Is yours a LR RWD? My LR RWD was manufactured in 11/18 and have almost exactly the same numbers for range as you do.Data point: I bought a used 2018 that was manufactured 11/18 and the previous owner purchased in January of 2019 so the car is a year old. I’ve only had it 9 days.
80% shows 240 miles of range, 90% at 270 miles. So 100% will likely net 300 miles.
Mine is a LR DM. Though I’d imagine battery packs are the same.
We picked up our new 2019 AWD Model 3 in August of 2019 and we've run it up to max charge only a few times, but we've never had a screen indication of more than 304 miles. We've had all the updates but still haven't seen that 325 mile range update, or even the original 315 mile range. I charge mostly at home using a 14-50 charger. Any suggestions on how to reach that mystical 325 or even 315?Same here. I’ve had my LR RWD 3 w 19in Sport wheel since April 2018 and seen the initial 3% range degradation (yielding appr. 300 total range ) earlier this year. Then, a software update when Tesla announced the 325 LR 3 increased my total range from 300 to 315.
The most recent update 2019.20.4.2 update that included Beach Buggy reduced it to 310 compared to the 315 I was getting with version 2019.20.2.1.
Doubt this is Range degradation but Tesla discontinuing the 325 mile LR model 3 altogether.
Thoughts?
AWD is capped at 310 on display (btw this is for pre 2020 End of 2019 models - the newer ones seem to be rated at 322 but not sure if it is a constant update or an efficiency boost). But you can still get more out of the car, rated miles is just a "number".We picked up our new 2019 AWD Model 3 in August of 2019 and we've run it up to max charge only a few times, but we've never had a screen indication of more than 304 miles. We've had all the updates but still haven't seen that 325 mile range update, or even the original 315 mile range. I charge mostly at home using a 14-50 charger. Any suggestions on how to reach that mystical 325 or even 315?
Interesting, but I don't quite trust this app because Tesla claims 310 for the P on their website so I guess they at least have to display the 310 when full.Alan, I have been using Teslamate logging software and it gives me the actual rated calculation it derived from the car, so we officially have the number 264wh/mi for the 2020 performance + on 20" weels.
side note, its claiming 291.5 miles at full charge (x 264wh/mi) 76,956 KWh
So they actually increased the efficiency constant for the 2020 models. Is the AWD 2020 still 310 miles on display or 322 as it says on the website?
Not sure if this applies, but on the app if you pull the slider on the charging screen it gives you a mileage for each of the "lines". Mine changes daily. Both up and down. I saw 313 yesterday, I see 307 now.
This is depending on cell temperature. Once the battery cools down you see lower values. Even though you are in California I am sure you have below 10-5C temperatures over night so this could affect that estimate greatly.Not sure if this applies, but on the app if you pull the slider on the charging screen it gives you a mileage for each of the "lines". Mine changes daily. Both up and down. I saw 313 yesterday, I see 307 now.
By the way, I just watched some SR+ videos with Scan My Tesla data and it seems like the calculations constant for the range is at 136.3Wh/kmJust a projected estimate, discussed above somewhere I am sure. The potential error due to rounding error will increase the lower is your current state of charge.
