I have a 2020 P3D- Stealth (19" rims) for reference. Telsa rolled out that FSD update and i lost 10 miles due to having different rims.
Teslafi also has a new fleet battery graph where you can compare your battery to others.
310.04 and after this latest charge im at 311.7.
why im like the only one who seems to have had that dip
The "power boost" was not an "energy boost".
(i.e. it increased performance not range.)
Yeah, all that did is update the constant. No energy change. Looks like different number of miles due to different constant. Looks like you went to 299-ish. I think most people on that interim update with 19" wheels were at closer to 301rmi (77.6kWh/0.258Wh/rmi). So you might have already lost some capacity. And then you lost maybe a little more.
The thing is is that there was a 2020.4.1 update which should have bumped your range number up slightly due to a slight constant adjustment - but I don't see that here in your plots?
A bit confused by what you see, but what it boils down to really simple: know what your charging constant was at any point in time, then it should all make sense what is going on.
You energy will very likely not be changing as you go along - except possibly due to capacity loss (hard to know based on this data).
Yeah, not sure how they will handle this. This is the peril of TeslaFi not tracking available energy (it's possible that somehow they do, though - I have no idea). If they do track energy somehow (seems like probably not since they don't normalize your rated miles number) they're just correcting for it before showing you the plot
Probably just incomplete data from TeslaFi
True. No energy change.
I'm not sure we really know this, though. Unless the hardware changed in a way that allowed better efficiency (possible), it appears that software changes have allowed them to improve efficiency. Which would mean that one of the software updates (possibly not the same one associated with the power boost - but it could have been) may have improved efficiency.
I requested this feature recently and he said he would make it, with custom 100% starting range and the dev did it!
This is my absolute “best” I achieved ever:
Imgur
Average is 340km of the 386, but has been even 10 lower 70% of the time I have the car
still there are 0% below my rated range (with same 500 + or - miles/kilometers)
we need more SR+ on Teslafi.
We decided were driving 2300km x2 to portugal from Nl and to northern Norway without a boat, 4400km x2 with our SR+ this year. If the battery survives.
Yes, everything is like I expected it.. UnfortunatelyDo you have the Scan my Tesla App yet? If so, please let us know what your nominal full pack reading currently is. Ill venture to guess 2 things are happening here, either your car is misconfigured as a SR non plus or theres something seriously wrong with the battery (ie defective module or something to that extent). Others can chime in here if im missing something
In your 2nd screenshot I see the cell imbalance at 64mV which is the likely cause of this. Others can chime in here on why that is, but since youve been experienced this since it was new, it almost seems like it left the factory with some substantial cell imbalance. 47 Kwh nominal full is extraordinarily low and should be investigated. FWIW, my car is typically around 4mv of cell imbalance
That seems like I have no degradation but i don't think thats true due to only having like 75kWh instead of 77ish right?
in this case I preheated 1.5h and then charged (for testing) to 100% and drove off: 100% to 6% (41kWh) manual calculations estimate 43-45kWh useable capacity at best.
I can agree, higher this imbalance V,
I agree something is off, I planned a service a few weeks after I got the car (then had to wait 2months).. They couldn’t really tell me anything besides “i see no errors” and indirectly hinted to the website where it says warranty is -30% (while at same time telling me pack capacity is secret and not public)In your 2nd screenshot I see the cell imbalance at 64mV which is the likely cause of this. Others can chime in here on why that is, but since youve been experienced this since it was new, it almost seems like it left the factory with some substantial cell imbalance. 47 Kwh nominal full is extraordinarily low and should be investigated. FWIW, my car is typically around 4mv of cell imbalance
This would explain alot, imbalance vastly increases during longer trips, I am sure the 64mv (even though maybe for short time) could be valid, i’ll keep an eye on it thanks.I can agree, higher this imbalance V, it means you have a leeching drain cell somewhere which just self discharges all the time. Others keep feeding it power to balance. Unfortunately this will happen over time to everyone.
Thanks for that calculation and basically telling me I am not stupid, but probably right.I think you have loss of capacity, yes.
Yep, all makes sense.
41.3kWh / 0.96 = 43.9kWh (trip)
43.9kWh (trip) /(0.955) / (0.98kWh(trip)/1kWh(battery)) = 46.9kWh (battery)
Lines up very well with your ~47.1kWh. (215 rated miles, 346 rated km, for a 2019 SR+)
Probably just bad data. Way too large to be real.
(also have a not posted screenshot where it sais 64mv
If there is a bad “block” i imagine it might have to bleed off the constantly increasing imbalance?
3 months in. About 6k on the odometer. My Tesla core shows .5% loss in the battery. Does anyone have another Android app that will corroborate? If this continues and is accurate a 6% loss in a year which would be roughly 30% in 5 years. Im.notnsure how normal that is.
Here is my battery degradation report (beta) from TeslaFi for my P3- on 19" stock wheels. I am getting a little concerned as my battery range has dived below the fleet average, -4% so far to 291 mile range at 100%. I usually charge to 80% but a few times a month I charge to 90% to calibrate the range estimate.
Is there a spreadsheet where I can add my data and see other people's data?
My range was stable at 309-310 then dropped pretty quickly to 300 then again to 292. I hope it levels off, track mode v2 won't help muchThat's super interesting how we have the same car. P3D- stock 19s (mine is 2020) but you didn't see the instant 10 mile drop I did on the fsd preview update. We have about the same range though. I'm at 295 @ 2200 miles.
Just for fun I set my rims to 18" and did a 90% charge and saw a big boost in range negating what I lost in the update. Obviously not accurate due to rim size loss of efficiency but interesting. View attachment 520165
For what it’s worth- @ 22000 miles, 16 months of mostly commute driving, my 90% shows 264 miles @ 90% and 293 miles at 100% state of charge. My Model 3 is still plenty quick and every day, I still enjoy driving this precision, souped-up fancy golf cart!!
i bought my model 3 in aug 2018. After the software upgrade I only got 316 miles when charged to 100%. Last night I got only 312 miles from 5% SOC to 100%. A 4% degradation within 10 months? Have others degraded similarly?
