We paid for one thing, we got something. Not sure about the US, but in Australia this is against the law.
I don know about what system Aus use for advertising range.
EPA, thats the US Environment protection agency setting the norms for how to measure. Also, they clearly say the EPA range is for comparison and isnt the true range:
WLTP which Europe use claims to be like real driving but as the average speed is 53.5km/h you need to use a very low speed or have a huge part of the driving session att low speed to come close to this consumption and range.
WLTP is 12% more optimistic than EPA for my ’21 M3P.
Both EPA and WLTP use test temperature somewhere about 15c. The heater and AC is set to off. An electric car needs to use the bsttery energy to hest the car, or at least drive the heatpump with battery.
When wishing to reach EPA range, you need warm klimat, AC off and keep speed down to be within the EPA test range. And you need to drive it beyond 0% which isnt wise, but its possible to do it.
Colder climats with heat pump on will not reach the EPA range.
As for the degradation, no one can or should expect the car to keep the advertised range forever. The nature of electric batterys as we know it today is that they will degrade.
Degradation will depend on a lot of factors, so it will differ from car to car.
Heat x time degrade lithium batterys more. If you live in a warm climat and the car is at elevated ambient temperatures its battery will degrade faster then a cold climat, for the storage part of the battery degradation. If you can keep the bat at maximum 60% as the highest charge point and in cold conditions, itll degrade slow. Often needing to charge high plus combined with a hot climat will have a negative effect on the battery.
We know degradation is higher in the beginning of a battery life and then most often almost stops, and get very shallow if used as the average car. Model 3 seems to report slightly higher degradation than S/X but still this can be differences in the BMS.
We have the Teslabjorn on youtube that tested true battery degradation by driving got 8% degradation after 2 years / 80K km and he had some 64% AC/ supercharging which is suposed to be bad for the battery. His test was done during winter/cold climate and he guessed that a degradation test during summer would show lower degradation( perhaps 7%).
To sum it up, when switching from ICE cars to EV you need to adopt the nature of EVs, and probably it takes some time to get adopted. Id say, it is not Teslas or any other EV car makers job to assist you with all the facts. Even if they tried, most buyers would say “yayayaya, give me the key so I can go ‘n drive”.
What I see here and at another forum is people going into the EV world without have done the appropriate research before, which means they didnt really understand what they bought until after they got the car.
