I have tried a couple USB sticks which I've formatted and have working well for dash cam / sentry recording. However I can't get the media player to recognize either drive for audio files. I have ONE partition and two folders - "TeslaCam" and "Audio". I've not heard that a separate partition is necessary for the audio files. Might this be my problem?
Is it possible to use two USB drives simultaneously - one for TeslaCam and the other for audio files?
Maybe, Ive tried wireless charging pad with splitter cables, doesn't work. Then I got the Jeda hub which has the compartment for the DashCam/Sentry. Works for a week with intermittent results then I have to reformat everything. I use a 128g scan disk flash drive (you don't want thumb drives, use video camera flat drives with adapter for video) and still got a warning about the drive after the last update. I formatted everything again and it worked for a week and same issues or not showing Music drive which is a thumb drive.
So far what seems to be working
Cheap Amazon USB hub not powered, I plug the USB music and charging cables in to the hub in to the left side and the USB flash drive 3,0 adapter in to the right (they don't seem to like to be on a Y or hub). Been working for a week. Im asking Jeda what gives since I spent $100 for nothing.
Charging pads suck because they are throttled so I stopped using that and went to the cable.
For FAST phone charging get the PD 12V adapter under the arm rest with USB-C, the proper cable and it charges very fast, just like the included wall charger if you have a new phone
That 12V should be in the front, not under the arm rest then there wouldn't be any problems, they really didnt think this through and don't even have an official response on how you are supposed to make all 3 work with 2 ports
