its kind of funny, in a way; I recommend higher priced industrial grade sd-cards and I get pounced upon, saying its overkill.
Because it provable and factually is.
You've been shown the math several times now.
but do you have any idea how much it would cost for a true auto-grade ssd to be built into the car, that will have enough wear that it can do the job and last for, say, 4 years of cam usage?
Did you miss where it was shown to you, repeatedly, how utterly unneeded "high grade" anything is to last 4 years?
A 128GB drive, even with relatively average consumer-grade flash, is going to last significant more years typically. And 256GB one double that.
Because, again, basic math:
A decent consumer grade flash drive from Samsung or somebody using TLC is gonna be rated for 3000-5000 complete write cycles. Let's go with the
lowest end of that range, 3000 write cycles.
Teslacam is writing ~7.2 gigs an hour... so 9 hours a day common use (8 hours at work, 1 hour drive to/from) you're writing 64.8 GB a day.
A 128GB key would use 1 full cycle every 1.975 days. Let's call it once every 2 days for easy math (and you're probably using it less on weekends anyway).
3000 cycles times 2 days= 6000 days... or about 16.4
years to use 3000 write cycles.
Over 32 years on a 256GB key.
Even running dashcam 24/7/365 works out to using up 1.35 cycles per day... (3000/1.35)/365= just over
6 years of 24/7/365 use on a 128GB key.
Over 12 years on a 256GB one.
And again that's using the low end expected life of the drive.
I mean, it's your money- waste it however you like.... meanwhile my 128GB Samsung USB key has continued to work flawlessly for 16 months now, no issues.
Once every 3 months or so I pull it, clear out unneeded saved stuff (because all flash tends to slow down if you let it get really full), and put it back in.
