stopcrazypp
You can use CrystalDiskMark to check if the write speeds really have degraded on the drive. I use this portable version (so I don't have to install)It was working for a while. The Samsung Fit Plus is 128 GB. Sentry mode is turned on and disabled for home. The Fit drive is usually empty since we do not drive the car much (<2,000 miles in 18 months).
Also, having the car format the drive does not fix the error.
Downloading File /75252/CrystalDiskMark8_0_2.zip - CrystalDiskMark - OSDN
On Mac, there is a similar utility here:
AmorphousDiskMark
It would be helpful to compare if you did a test when you bought the device, but it's hard to go back. But from reviews the 128GB version typically range from 40-80 MB/s for sequential writes. There is a review that mentions Sentry mode and says it can't get 4MB/s for write (but it might just be from them seeing the same Tesla error you see). There might also be counterfeits out there (or Tesla's software update affected things).
Amazon.com
You can try reformatting on a computer. I use guiformat to format my card to FAT32 (make sure to select correct drive). You can uncheck the "Quick Format" to do a more thorough format.
Ridgecrop Consultants Ltd
With Mac the default utility can do the same thing and you can select "zero out the data" to do a more thorough format. Usually this isn't necessary on a drive with solid state memory (plus it adds a full cycle of wear), but in this case you have nothing to lose.
Erase or Format Your Mac Drives With These Security Options
Usually with a 128GB drive with the drive mostly empty, the wear on it shouldn't be high enough to affect the speeds (as it can do wear leveling). But anyways, as discussed up thread, I personally chose to use a high endurance SD card instead, given that is rated for *minimum* sequential write speeds and it's warrantied for wear.
