The quick answer is that you aren't measuring your car's range, and your range is likely normal.
I am only able to go ~146 miles on a fully charged (100% to 0%) battery per my test this week.
I charge the car to 100% and then drove it down to 5% and only went 138.4 miles using 52 kWh (see image link).
This was not a continuous drive so the remaining ~15kWh was lost while sitting, either due to just general vampire drain, or feature drain (Sentry, Smart Summon Standby Mode, preheating the car, etc.). These losses are
not included on any of the trip meters. Those meters only show use when you are not in Park.
The projected battery power is also only 54.7kWh instead of 75kWh (see spreadsheet image link).
As described above, you can't do it this way unless you have done a single continuous drive.
Note also that the snowflake means that your available energy is reduced so that may introduce some error in that 54.7kWh calculation.
For the record, the correct description of the units here (kWh) is
energy, not
power.
I'd recommend making sure you have Summon disabled or at least Summon Standby mode disabled. And don't use Sentry mode unless you need to (if you want to preserve your energy for some reason).
You should expect to use about 1kWh of energy per day due to normal vampire drain, and this will not show on the meter.
At max, the most you will likely see on the meter for a single continuous (no parking) 100% to 0% discharge (assuming your 100% is currently 310 rated miles) is about 72kWh. However, that result would imply your battery has a total usable capacity of about 76-77kWh. (The reasons are described
elsewhere but that's the way it works.)
What range you get from that 72kWh of course will depend on how you use it. If you average 377Wh/mi, you'll travel about 191 miles. If you average 234Wh/mi, you'll travel 308 miles.
