MASTER THREAD: Winter charging issues, frozen charge ports, road trips
Is my cars range considered normal?
  • Yes
    Votes: 28 82.4%
  • No
    Votes: 6 17.6%
  • Total voters
    34
RFernatt
Solar/EV Owner/Enthusiast
Oct 13, 2016
645
3,363
Eastern Panhandle, West Virginia
Do you remember what trip planner arrival predicted? Just curious how accurate it was. I think those numbers are quite good especially given elevation and an approx 40wh/mi addition due to hvac.
ABRP predicts 15% at 30 degree and no wind, but those were variable during the trip. I didn't use the car's nav since it was a common trip for me and I wasn't actually charging in Martinsburg, just stopped to get the photo and then another 10 mins to home.
chrisf60526
89
87
Chicago, IL
Rude awakening this weekend in my SR+. Picked my car up mid December so it's cold here in Chicago the whole time i have had the car/
100% charge, cold weather at ~33 degrees. First leg trip i went 70 miles and used 49% of my capacity. The only variable, and a big one at that, is that we had 5 in the car. Me, wife, 2 kids, and mother in law (who is not that small). I'd estimate the the weight at 650lbs total. Luckily, there was a SC 11 miles away or this would have been tight.
I estimate i lost ~33% range with the extra weight and weather based on my calculations. Not complaining but as a newbie, you gotta think about this.
Reactions: Arctic_White
Tessaract
332
318
Ottawa
There are many reasons for reduced range in cold weather, discussed in detail above in many other threads, so I won't repeat them. But my opinion is that the weight of your MIL doesn't much matter, it's the temperature (the most important aspect of weather, but not the only one) that matters here. Speed, snow, rain, are other weather aspects. All matter.
Halifax_NS
New Member
Jan 15, 2020
4
5
Halifax, Canada
Hair dryer instead of water?
I'm extremely close to my first Tesla purchase but hearing suggestions to use water or a hair dryer to disconnect from a charge, especially given our climate in NE Canada, I'm a bit hesitant. Tough for me to spend 70 grand on a car that I need a back-up hairdryer in the back seat in order to use it. hmmmmmm
someone please convince me otherwise!
GPinzone
316
168
Ronkonkoma, NY
A hairdryer won't work. It was 20 F outside and my hairdryer couldn't heat up the cold air to make it warm enough to make a difference. I thought the emergency release in the trunk was frozen, too, but after a mobile service call, I discovered the manual release cable was never connected at the factory! I suspect the manual release would have solved the issue. I also took a preventative measure by spraying Deoxit DN5 into the charge port, which should clean and lubricate the connections as well as the locking pin. However, I haven't had may an opportunity to "torture test" since I haven't had many super cold and wet overnight charge conditions. The few that I've had didn't require anything special. BTW, spraying Deoxit DN5 in the 240V NEMA 14-50 outlet made plugging and unplugging a snap. It used to be really difficult and now it's easy. I only had to apply it once.
Halifax_NS
New Member
Jan 15, 2020
4
5
Halifax, Canada
yeah, my point is really whether or not it's time to invest 70G into a car that doesn't have relatively minor things like this figured out. Seems like they've perfected a battery powered car without paying attention to fine details like this. A bit discouraging.
Tz00
3 LR AWD
Jan 5, 2019
274
523
NB, Canada
I exclusively park outdoors and have never had issues with the charging cable getting stuck. I've never used the emergency release. Tesla did replace the locking mechanism with an improved part specifically for frozen port issues. They did that on their own. I didn't request it.
Prior to owning the car, I had some hesitations owning a Tesla in the Canadian winter, but there is nothing that makes me regret the purchase.
Reactions: richyrich
Mansley
133
107
Toronto, Canada
Hey there, I totally get it. I’m in Toronto and just had a car wash a few days ago in -10 degrees. Left the car overnight and the handles and windows were frozen. It’s sooo annoying to push a button on your app while in bed to warm the car... That’s such a small issue to worry about in the grand scheme of things. It’s happened ONCE in 9 months of owning the car and 25,000km and could probably happen in other cars.
As for the charging port, a gas tank could freeze shut too. Also your hands get cold filling up gas all the time.
At this time, my 2013 Nissan Altima had way more issues and cost me about $50/month less than my Model 3 factoring in all maintenance, gas, insurance, depreciation, etc... not to mention frostbite in -40 in Manitoba holding the stupid gas pump.
I’ll never go back.
Halifax_NS
New Member
Jan 15, 2020
4
5
Halifax, Canada
I’ll never go back.
love it.
Reactions: Mansley
Space_CowBoy
38
17
Montreal
I thought I saw a few videos on Youtube that indicated that the charge ports on 2021s are now heated. Or was that always the case? Picking up my M3 in a couple of weeks and am not too worried about this since I'll be parked in a heated garage.
Mansley
133
107
Toronto, Canada
Yes, they're heated. Lucky you get your 2021 M3. The heat pump is amazing. My Model Y has a heat pump and I notice a substantial difference over my Model 3 without one in the cold.
You'll love it.
Space_CowBoy
38
17
Montreal
You'll love it.
Thanks! I was wondering if the heat pump would make a difference. Since you're in TO, I'm guessing you see some efficiencies with consumption over 2020 and below M3 owners.
Mansley
133
107
Toronto, Canada
Yes, it is a noticeable difference in range (approx 10-15%) with the heat pump in cold temperatures. And this is also factoring in battery size differences between my M3 SR+ and MY. The SR+ battery is much smaller, so it's impacted more in colder temperatures. I find it dropping 5-10% overnight if not plugged in depending on how cold it gets and then taking another 5-10% to warm up the battery.
The heat pump in my Y really helps out in cold weather.
zerb012345
127
52
Southeastern MA
Hoping this is the correct thread to ask this.
I took delivery of my 21 SR+ a few day ago on 12/12 and have Supercharged a few times now. Each time the speed has (seemingly) been slow at less than 30kw and only around 100-120 miles per hour. Each time I used navigation to precondition the battery, and the outside temperature has been between 30-45 degrees. Is this normal for the winter given the temperatures? At 150kw stations shouldn't the speeds be much higher?
Reactions: Mansley
astrowunder
455
422
Wisconsin
If you have more than 50% remaining in your battery or if the battery is very cold, this can happen. The charge rate slows as the battery is filled.
Mansley
133
107
Toronto, Canada
think of supercharging like filling a bucket with a firehose... you’ll slow down as it gets full.
also, preconditioning the battery helps a lot on your way to superchargers. I usually only start to supercharge my SR+ at between 10-30% and only usually up to 80 or 90%. It’s better for battery life and saves time.
Reactions: zerb012345
Neukwen
New Member
Jan 12, 2020
2
4
Winnipeg
This is great news! We typically lose about 30% range in winter. Are you suggesting with the heat pump, the loss would be only 15%-20% on the same drive? Living in Manitoba, we are wondering about the value of a future upgrade to a new M3 with the heat pump.
acarney
2,326
1,385
Richland, WA
I wouldn’t get excited. I think you’ll see great efficiency out of the heat pump down to about 30F, but below that you’re going to be closer to a COP of 1 (resistance heating). [Ok, realistically the unit might have a COP of 1.5 to 1.8 around that temp, but because of the size of the system it likely won’t be able to supply the amount of heat to quickly warm the cabin just from collecting heat in the air so it’ll pull electricity from the pack to supplement] Heat pumps aren’t magic, there has to be sufficient heat in the air for it to concentrate and pump into the cabin, just like home heat pumps; most people have backup electric coils that run in very low temps (sub 30F). If you look at any chart of a home heat pump the BTU output usually is 50% of it’s rated amount down to maybe ~30% once outdoor temperatures are down to 20 to 30F.
Now the Tesla system is a little more than just a heat pump. The system also connects all the electronics into the same heating loop. If the motors, battery, or inverter has waste heat from usage than the will get pumped away by the heat pump and added to the cabin. I think on “short” [maybe less than 30 miles) drives you won’t notice much of a difference since the battery will still be warming up and the motors and other electronics don’t produce THAT must extra heat, otherwise they wouldn’t be so efficient. In addition, low speed drives with a lot of sitting in traffic won’t be able to scavenge much heat from the motors since they won’t be running while not moving. Expect the heating system to operate approximately the same as the older Model 3 system.
Now potentially on very long highway trips (75+ miles) the battery and electronics may get to a steady temperature that the heat pump is able to pull some heat from them and add it into the cabin. This is essentially free heat (you already used the energy for movement and heat was left over) so that will greatly improved the efficiency of the heating system.
Also, the battery gets warm from charging, so if you usually need to do a fairly substantial charge every day (say 25%+) if you can do that RIGHT before you leave, you’ll have “stored” heat in the battery as a byproduct of charging (the energy came from your wall) which is “free” heat for the cabin. But if you complete the charge at 2am and don’t depart till 8am, you won’t see this gain.
If you usually charge the moment you get home at 6pm and the charge is done by 8pm and you leave every morning at 7am for your 5 miles to work... don’t expect much or any improvement when temperatures drop to 30F or below. If you used 350 Wh/mi for the 5 miles to work (1.7kWh) in the 3 with resistance heating, don’t expect to suddenly use 245 Wh/mi (1.2kWh) with the heat pump.
Don’t get me wrong, it is an AMAZING system and engineered really well, but it isn’t magic. The fact is there isn’t a giant inefficient part of the car that just spews out wasted energy as heat, so the car barely has any heat to collect other than from the air. On long drives to maintain the loss of heat from the cabin to the outside the heat pump capacity might be able to keep up just from pulling from the air and might be COP of 1.5 to 1.8 (1kW in produces 1.5 to 1.8 kW worth of heat) but on shorter drives where you have to warm all that air up to a comfortable temp, expect about the same as the resistance heater.
Reactions: Jon.W.
