MASTER THREAD: Winter driving advice, winter tire choices, etc.
Discussion in 'Model 3: Driving Dynamics' started by Colgate2004, Nov 15, 2018.
  1. natman316
    natman316 Member
    Bay area
    #521 natman316, Jan 22, 2021
  2. GregD60
    GregD60 Member
    Colorado
    Definitely different from the Model Y wheels.
    I can confirm that they work just fine on all Model 3s since I'm running a set of the Model 3 Gemini wheels on my LR AWD. The wheel centers don't engage to the full depth of the hubs, but there's more than enough engagement to center the wheels properly on non-performance Model 3s. There's also 5mm less offset, 35 vs 40mm, but I've noticed no negative impact from that. Many people run much lower offsets on aftermarket wheels.
  3. jlghertner
    jlghertner Member
    Sodus, NY
    #523 jlghertner, Jan 27, 2021
    I know there are multiple threads that I can’t figure out how to post to.
    I don’t expect a new conversation on this.
    I just put on Conti pure contacts. My M3 now drives like a Subaru on wet snowy icy roads.
    I wish I knew how good my Tesla would drive with these tires or I would have replaced the worthless Michelin’s on day 1; they only lasted 18,000 miles anyway.
    (moderator note: moved to master thread on winter driving)
  4. clyde
    clyde Member
    Cincinnati
    #524 clyde, Feb 15, 2021
    Three winter driving issues (not related to tires/wheels!):
    1. My brake pads regularly freeze to the calipers during inclement weather after a few hours of not driving. A sharp and probably unhealthy “crack” frees the linings when I drive off again. On ICE cars, the rule on freezing days: leave in gear with hand brake off.
    Is there a setting in the Model 3 to also leave the parking brake off (it seems to automatically apply the brake when I exit)?
    2. Wiper options are insufficient in inclement weather: every change takes my eyes off the wintry, icy road and my right hand fumbling through menus.
    Even one second of screen distraction is too long on ice, when I want activation NOW. “Auto” in snow or ice rain is erratic, Level One intermittent never comes on at quite the right moment, and toggling between off and any other choice is distracting, as the wiper window quickly closes after each choice, and I have to go back to the main menu. There HAS to be a better system!
    3. Is Slip Start Tesla’s only way to turn Stability Control OFF? Or is it also off in track mode?
    My brake pads regularly freeze to the calipers during inclement weather after a few hours of not driving. A sharp and probably unhealthy “crack” frees the linings when I drive off again. ≈
    Is there a setting in the Model 3 to also leave the parking brake off?
  5. navguy12
    navguy12 Member
    Eastern Ontario
    If you are talking Model 3/Y, one is able to press the button on the end of the turn signal stalk for a single swipe "now".
  6. clyde
    clyde Member
    Cincinnati
    Yes, aware of it on my M3, except: that button also activates the window washer, and it's almost impossible to activate wipe without wash. And wash in freezing rain = visual obstruction. It would already be one step ahead if the wiper menu would stay put on the screen until I delete it. That way, I am one step closer activating a change, and one step further removed from visual distraction.
  7. navguy12
    navguy12 Member
    Eastern Ontario
    Interesting, I wonder if the mechanical dynamics of that button have somehow changed since my early build from May 2018.
    I've never had an unintended wash, ever.
    My button has a very firm mid point stop, infact to get a wash I have to really force it beyond the mid point stop to get a wash.
  8. birdsquared
    birdsquared Fan-man (too old to be a fanboi)
    Burnaby, BC
    I have a March 2020 build, and I have also never had an unintended wash.
  9. LesT
    LesT Member
    Bancroft, MI
    I need new tires..long overdue, actually. Any recommendations for nice all weather tires? I don’t want studded, but I do need tires good in snow. Model 3, LR AWD
  10. KenC
    KenC Active Member
    Maine
    There's a new category of all-season snow tires, with the 3PeakMountainSnowflake designation. Like the Michelin CrossClimate+ or 2, and the Vredestein QuatracPro or 5, etc.
  11. HyperionMark
    HyperionMark Member
    Brookings, SD
    Love our CrossClimates!
  12. tij664
    tij664 Member
    Turlock, CA
    6BCF3F8C-A79B-430E-AC0D-761F1AE28DE6.jpeg 879DD75C-8BA2-4E07-8899-0AAC73D805E0.jpeg I figure this will help someone when it comes to deciding on winter tires.
    I live in the Central Valley of California and in this part of California it doesn’t snow and generally the coldest temps in winter will be in the 30’s overnight with the rare hard freeze which can bring the temperature in the 20’s for a few morning hours. That only seems to happen once every few winters and is not typical. Obviously I love the stock 20” PS4s that come on my 2020 Model 3 Performance with their insane dry grip but I figure they’re probably unsafe in snow or ice. Being that I wanted to take road trips in the winter time such as Tahoe, Mammoth, or Washington and Oregon I decided to purchase a set of 18” wheels with more suitable tires for snow. I didn’t want dedicated snow tires such as Michelin X-Ice since two or three winter road trips for perhaps a week at a time at most per year did not warrant investing in an all out winter tire.
    I ended up deciding the best situation for me was the Michelin Cross Climate+. This weekend I drove to and from Mammoth Lakes for the weekend. My initial drive on Friday had me drive on 88 eastbound from the valley into the Sierras and after about 5000 feet the light rain turned into snow. It’s a winding road through the mountains and daytime temps seem to be in the high 20’s. After arriving Friday night in Mammoth the temps dipped to about 9 degrees overnight and it snowed a few inches. I parked the car outside on an inclined driveway while in Mammoth.
    Driving on snowy and icy surfaces including hills, and hairpin mountain roads was just phenomenal with these tires. They just bite in and the tires inspire tremendous confidence in ice or snow anywhere I went in Mammoth and the surrounding areas. With overnight temps in the single digits and low teens the tires maintained their composure regardless of the very cold temps.
    When I got back home the weather was sunny and about 67 degrees. At lower elevations driving on hills and winding roads the tires give great feedback and hold their own when it comes to dry grip in milder weather.
    I would wholeheartedly recommend these to anyone debating on what all season or winter tires to get. I’m sure those that live in harsh winter climates will benefit from a dedicated winter tire but I feel even those of us that will only use occasionally in the snow and want a tire for truly all seasons, this may fit the bill perfectly.
  13. PNWLeccy
    PNWLeccy Member
    Seattle
    #533 PNWLeccy, Feb 22, 2021
    I'm in a similar situation here in Seattle where the weather is always mild but wet. Not only do we almost never get snow here but winter tires usually perform poorly in wet conditions, which is not good in the PNW. I go up to the mountains a lot for skiing and while I don't feel uncomfortable on my drives up, I have a tough time in the packed snow parking lots at Stevens Pass with my stock 19" Contis and RWD.
    Does anyone have experience w/ a 3PMS rated All Weather tire (CrossClimate2, Quatrac Pro, etc.) w/ RWD on snow? I have gotten stuck a few times in the parking lot, even with a Slip Start and Auto Sox and am trying to figure out if tires will fix my issue or if my fundamental issue is lack of AWD. I know that tires are the most important thing so I'm hoping that will solve my issue until I can upgrade to a LR Y AWD.
    Note: I knew the stock All Seasons wouldn't be great but these tire rack comparisons really validate how bad they are in the snow and ice. tire compare.PNG
