Max Battery Power setting in P90DL
There's a rumour floating around that the P85D takes 2.9s to get to 60 instead of the 2.8 of the P90D and that's because the cell impedance is lower in the new cells so the voltage drop under high load is less, meaning that you can get more power out of the pack at a given current level.
This development would seem to fit in well with that.
It would also suggest that the P85D won't get this max battery power setting.
That was a rumor. Also additives like silicon that increase how many Lithium Ions that anode can absorb tend to increase impedance. The price for increased capacity is often decreased maximum current. So if they didn't manage to increase the impedance of the new cells with Silicon, they must have discovered something revolutionary to get around it which is quite possible.
It's probably using the electric pack heater to raise the temp. Pete90D reported he heard the "whine" while stationary. This noise is the glycol loop pumps ramping up to high. Sometimes during a reboot you can hear the same thing happen if the car was/is charging.
Very cool new feature. I found out the same behavior myself with my P85 from 2013. When I was having a warm pack, right after Supercharging for example, I was logging much higher, often more that 470hp (from KW conversion) with the REST api.
One example I have here is 357kW (479hp). Otherwise with a battery at "room" temperature, I usually cannot see more than 337kW (452hp).
I'd like to get that max battery power mode in the P85! Please Tesla!
It would be nice to know, what is pack's spesific heat capacity. Was the electric heater 4.5kW? I think it will take several minutes to heat the pack if it is cold.
Yesterday afternoon when I charged it was 72F outside, and it took about 10 miles of driving before it was "Ready". Last night when I drove it was 65F and it took only a few miles. So I'm baffled by this max power option, when to have it on, when to have it off...
The Roadster also has a Performance charge mode that holds the pack at a higher temperature to improve 0-60 times, but with a trade-off in increased wear on the cells.
I doubt Tesla would switch suppliers unless it's just a stop-gap until the Gigafactory is online.
Sanyo is subsidiary of Panasonic
https://en.wikipedia.org/wiki/Sanyo
- - - Updated - - -
If 90 kWh pack cells are Sanyo NCR18650GA, that would make pack capacity 90 kWh with 1 amp cell disharge
see https://www.fasttech.com/product/2399300-authentic-sanyo-ncr18650ga-3-6v-3500mah
On the other hand 85 Kwh pack has more like 81 kWh capacity with 1 amp cell disharge
see http://www.teslamotorsclub.com/showthread.php/45063-Tesla-Model-S-18650-Cell-Test-Data
So difference is almost 9 kWhs?
