I think I already know the answer to this question, but perhaps someone out there that DOES actually know can confirm it? When you "navigate" to a supercharger now, the battery pack gets warmed up, but to my understanding, it only warms up to around 30 degrees celsius if the drive time is long enough? This will enable you to charge at a higher rate (depending on SOC). Now if instead, you were to enable max battery power and actually warmed up the battery to 50 degrees celsius, would that then allow the batteries to charge at an even higher rate........say perhaps 30-35%?
