Max charge: 407 km rated range, actual capable rated range: <380 km (@ 190 wh/km)
Discussion in 'Model S: Battery & Charging' started by mlaureti, Jul 28, 2014.
  1. mlaureti
    mlaureti Member
    Gatineau
    #1 mlaureti, Jul 28, 2014
    Car says: max charge at 407km of rated range. (Meaning: 407km if consumption is 200 wh/km)
    At the end of the trip (without stopping): The car did 377 km with average energy of 190 wh/km with 4km left.
    If I understand this properly, my real actual max charge gives me less than 380km of rated range on a full charge. (< 237 miles)
    This means I lost more than 50km (>31miles) after 1.5 year, am I correct?
    Have you noticed the same degradation level?
    I attached a picture of my last trip, it is in km. Next time, I will set the unit of the car in miles.
    No air conditioning / heating was used during this trip
    Thanks for sharing your numbers / real life experience about your actual capable rated range.
    I also created a shared public spreadsheet: Battery Stats - Google Sheets
  2. Mario Kadastik
    Mario Kadastik Active Member
    Rae, Harjumaa, Estonia
    I have noticed too that one has to spend 190Wh/km or less to be about on-par with the typical range deduction, the reason seems to be that starting from some firmware (5.9?) the climate usage isn't reported in this usage. Therefore your actual Wh/km are higher. When I got me car in Dec '13 I could spend 79kWh and still drive (battery indicator showed 4% remaining even though I was 10km already past charge now. Now it's more like 70-72kWh from full charge that I'm approaching 0 with far less behind charge now. Though I usually range charge to 398-402km I've been able to go 396km with 24km left snd average around 186Wh/km, but it wasn't a hot day so cooling probably didn't work that hard.
  3. RiverBrick
    RiverBrick Active Member
    Mount Washington Valley
    I believe there are still 4-5 kWh available as a reserve after you hit zero. This would mean that you have a total of ~77kWh. If a new 85 offers ~81kWh, you're down 5%. I'm not sure how that compares to average given the age of and kilometrage put on your battery.
  4. Kalud
    Kalud Active Member
    Montreal, QC
    Corrected. Rated range is not at 200Wh/km but more like 178Wh/km.
    Your numbers looks fine, 407 is on the low side (to me) but I'm only at 16,000km. I get 420km for a 100% charge, down from the 430 initially. But its hard to base anything on these 100% charge numbers because when I updated from 5.8 to 5.9 (or 5.11, not sure) I went back to 430km 100% range... Its an estimation, not an exact representation...
    For comparison, distance to 0 km remaining:
    At 178Wh/km I get 420km max (rated range is 420 for 100% charge on my car) 90-100km/h no headwind, flat terrain
    At 200Wh/km I get 365km (120km/h, no headwind, flat terrain)
    At 250Wh/km I get 305km (cold winter, snow)
  5. mlaureti
    mlaureti Member
    Gatineau
    Thank you for the Clarification Kalud regarding the rated value of 178!
  6. Cottonwood
    Colorado
    For my 85 in the U.S., I have found the rated miles = actual miles, Wh/mi factor to be 290 Wh/mi. 290 Wh/mi / 1.6093 km/mi = 180 Wh/km, pretty close to 178 Wh/km.
  7. Kalud
    Kalud Active Member
    Montreal, QC
    Okay, did some experiment this morning, the rated km is at about 183 Wh/km.
  8. mknox
    mknox Well-Known Member
    Toronto, ON
    I have not run my battery to anything below bout 35 miles, but I can tell you this: When my car was new, a Range Charge gave me 265 miles on the nose. I now get around 241 after 17 months and 31,000 miles of ownership. That's about a 10% reduction. In my case, it may not actually be that bad because I've never "tested" it by running it right down, and the car's calculation may be somewhat skewed by the fact that I rarely charge to full and run to empty.
  9. In2oil
    In2oil Member
    Calgary
    My Current TESLA which is only 7 months old and with 5060km. When purchased NEW i was getting @ 90% 474km. Now I get 471km. My Rated range is 364km or 226miles. My energy usage is quite low, I think, for a P85D. From NEW it is 189wh/km
    I am a little disappointed to see this much degradation to my battery with so little usage.
  10. Vger
    Vger Active Member
    Salt Spring Island, BC, Canada
    Many people have reported, and there indications from the LiIon battery literature, that degradation proceeds a little more rapidly at the very beginning, then levels off so a much slower rate for a long time (at least 5 years). So I would not be too concerned. Those of us with 3-year-old batteries are seeing very little additional degradation.
  11. mknox
    Toronto, ON
    Yep. See my post above from last summer. I'm now at 61,000 miles and seeing almost exactly the same numbers as I did 14 months ago.
  12. sandpiper
    sandpiper Active Member
    Ontario, Canada
    I forget where I read it, but ideal range is based on 188 wh/km. And I've found that this works out pretty much exactly on my various trips.
