Max charge % just dropped??
Discussion in 'Model S: Battery & Charging' started by montgb, Aug 15, 2017.
  1. montgb
    montgb Member
    Northern VA
    Hi all,
    New owner of a used P85 here. My car is parked in my garage and plugged in while I'm away for a week on vacation. I use the Tesla app now & then to check on things (and show it off to friends/family!).
    Yesterday the app reported "charging complete" at 228 miles, which is what I've come to expect as the 80% mark. However, today the app says 213 miles, charging complete.
    Is this something to be concerned about?
    Thanks in advance.
  2. TexasEV
    TexasEV Well-Known Member
    Austin, TX
    The "charging complete" message probably refers to the previous day's charging. When you're plugged in and not using the car it doesn't charge continually. I think it tops off every three days or so. Probably what you're seeing is the vampire drain that hasn't been charged back up yet. If you ever need the car to start charging sooner when you're in a situation like this, just move the slider to a higher percentage and charging will start.
  3. montgb
    montgb Member
    Northern VA
    Thanks TexasEV! Looks like you were absolutely right - I just check again and it is back to normal. I didn't realize that it doesn't charge continuously.
