Finally got around to pulling the $50 tesla plug apart, my plan is to attach a 12ga extension lead to the plug and have a simple 120v charger. My other thought (correct me if I am wrong, is that with the pilot wired to ground, I could pull 40A if I wired it to 240v with the appropriate sized cable.
In the mean time I’m going to concentrate on the 120v plug and simply splice into the wires deep inside the plug. Use some HT hot glue to Pott the cables and connectors and clip it back together again. It took 4-5 hours to get the case apart carefully cutting away at the vulcanized rubber. I preserved the switch for the longest time until I realized I’m never going to need it so I ended up cutting that out too so I could get more room in the plug for the connections. Next stop is to find a suitable extension cord with a 90 degree plug on one end.
