I've pretty much had all systems apart in cars from 2013 to 2015. If anyone wants to know anything in particular, LMK.
Here's some particulars: (2015 with VIN > 100000)
/proc/cpuinfo:
Kernel ring buffer:
If there is any doubt what CPU is present, see the last few lines above.
/proc/cpuinfo:
Code:
Processor : ARMv7 Processor rev 9 (v7l)
processor : 0
BogoMIPS : 1795.68
processor : 1
BogoMIPS : 1795.68
processor : 2
BogoMIPS : 1795.68
processor : 3
BogoMIPS : 1795.68
Features : swp half thumb fastmult vfp edsp neon vfpv3
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x2
CPU part : 0xc09
CPU revision : 9
Hardware : p1852
Revision : 80703
Kernel ring buffer:
Code:
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 2.6.36.3-pdk25.023-Tesla-20140430 (tomcat7@ci-slave9) (gcc version 4.5.2 (GCC) ) #see_/etc/commit SMP PREEMPT 1202798460
[ 0.000000] CPU: ARMv7 Processor [412fc099] revision 9 (ARMv7), cr=10c5387f
[ 0.000000] CPU: VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: p1852
[ 0.000000] DMA: 16MiB DMA coherent/WC memory allocated at 0xfef00000 phys
[ 0.000000] Tegra reserved memory:
[ 0.000000] LP0: 00000000 - 00000000
[ 0.000000] Bootloader framebuffer: 00000000 - 00000000
[ 0.000000] Framebuffer: fe700000 - feefffff
[ 0.000000] 2nd Framebuffer: 00000000 - 00000000
[ 0.000000] Carveout: 00000000 - 00000000
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] On node 0 totalpages: 517888
[ 0.000000] free_area_init_node: node 0, pgdat c0a45e60, node_mem_map c0a8a000
[ 0.000000] Normal zone: 1280 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 162560 pages, LIFO batch:31
[ 0.000000] HighMem zone: 2814 pages used for memmap
[ 0.000000] HighMem zone: 351234 pages, LIFO batch:31
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c1a99000 s4736 r8192 d15744 u65536
[ 0.000000] pcpu-alloc: s4736 r8192 d15744 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 513794
[ 0.000000] Kernel command line: qbcommit=2c8b46d tegraid=30.1.3.0.0 mem=2047M@2048M vmalloc=256M video=tegrafb debug_uartport=lsport usbcore.old_scheme_first=1 core_edp_mv=1250 smsc95xx.mac_addr=usb0:xx:xx:xx:xx:xx:xx nvsku=699-61852-0008-704 SkuVer=C ProdInfo=900-61852-4508-310 ProdVer=C boardrev=x06 qbp=aiw-604f60a qbbootpart=11 mtdbootpart=10 envpart=7 envval=xx qbconsole=console=ttyS0,115200n8 thispartid=10 rdinit=/sbin/init-stage-0.sh loglevel=1 lpj=8978432 security=apparmor apparmor=1 crossplex ip=off rw console=ttyS0,115200n8 mtdparts=tegra-nor:65536K@0K(whole_device),262144@0(bct),131072@262144(pt),1966080@393216(stage1_recovery),1048576@2359296(stage2_recovery),1966080@3407872(stage1_primary),1048576@5373952(stage2_primary),393216@6422528(env),5242880@6815744(recovery),27525120@12058624(kernel_a),27525120@39583744(kernel_b) ehci3=eth smsc95xx.mac_addr=toucan:xx:xx:xx:xx:xx:xx is_e1888=0
[ 0.000000]
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 2023MB = 2023MB total
[ 0.000000] Memory: 2043412k/2043412k available, 52716k reserved, 1416192K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] DMA : 0xff000000 - 0xffe00000 ( 14 MB)
[ 0.000000] vmalloc : 0xe8800000 - 0xf8000000 ( 248 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe8000000 ( 640 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .init : 0xc0008000 - 0xc045b000 (4428 kB)
[ 0.000000] .text : 0xc045b000 - 0xc09f2000 (5724 kB)
[ 0.000000] .data : 0xc09f2000 - 0xc0a46820 ( 339 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU-based detection of stalled CPUs is disabled.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:800
[ 0.000000] Console: colour dummy device 80x30
[ 1.706319] Calibrating delay loop (skipped) preset value.. 1795.68 BogoMIPS (lpj=8978432)
[ 1.706341] pid_max: default: 32768 minimum: 301
[ 1.706478] Security Framework initialized
[ 1.706527] AppArmor: AppArmor initialized
[ 1.706607] Mount-cache hash table entries: 512
[ 1.707098] Initializing cgroup subsys debug
[ 1.707117] Initializing cgroup subsys cpuacct
[ 1.707134] Initializing cgroup subsys freezer
[ 1.707223] CPU: Testing write buffer coherency: ok
[ 1.707449] Calibrating local timer... 449.71MHz, setting to 4.00MHz.
[ 1.796523] CPU1: Booted secondary processor
[ 1.806556] CPU2: Booted secondary processor
[ 1.816589] CPU3: Booted secondary processor
[ 1.816720] Brought up 4 CPUs
[ 1.816739] SMP: Total of 4 processors activated (7182.74 BogoMIPS).
[ 1.822619] regulator: core version 0.5
[ 1.822889] NET: Registered protocol family 16
[ 1.823698] host1x bus init
[ 1.824082] Tegra3: CPU Speedo ID 9, Soc Speedo ID 3
[ 1.824099] Tegra Revision: A03 SKU: 0xb0 CPU Process: 2 Core Process: 0
