MCU replacement new or old?
Discussion in 'Model S: User Interface' started by 88mph, Jul 8, 2018.
  1. 88mph
    88mph New Member
    Virginia
    I just got my old MCU replaced due to it being faulty. The new one is Model NA premium 1045006-00-D. Would they replace my older model with the same “older” MCU or would they replace it with the new updated hardware?
  2. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    I’ve seen posts that say MCU2 has different wiring harnesses and other items. As long as supply lasts, MCU1 replacements are MCU1.
    Unless you want to pay for the ‘upgrade’ which hasn’t even been proved to be possible as far as we know for sure. :D
  3. 88mph
    88mph New Member
    Virginia
    Thanks for the info!
  4. nwdiver
    nwdiver Well-Known Member
    United States
    Mine died to. Stopped routing; Basically the trip function stopped... everything else works. What happened to yours?
  5. gmontem
    gmontem Model S P01707
    Castro Valley, CA
    My MCU1 died on June 19. It wouldn't power on no matter what. I couldn't even charge because the car was stuck in Scheduled charging mode. Not even the Supercharger bypassed it.
    It took about 10 days to get my car back because as usual, the part wasn't available. My car was out of warranty so I had to pony up $2270.50 for the replacement. I hoped for an MCU2 but it was an MCU1.
    I wonder why my MCU part number is different than yours.
  6. P85_DA
    P85_DA Supporting Member
    Open browser check your user agent u can tell if u have mcu2 if shows intel Proc
  7. nwdiver
    United States
    YIKES! Yours was WAY worse than mine... since mine still mostly works I'm considering just using my iPhone for Navigation and holding out for MCU2. Is your new unit any better than your old one before it broke? Looks like you got a 'B' and I'm getting a 'C'... My VIN is 3297; our cars are practically siblings... may have been on the line at the same time... our MCUs were probably from the same batch... Hmmmm
  8. gmontem
    Castro Valley, CA
    My new MCU feels the same as my original unit.
    • Informative x 2
  9. gmontem
    Castro Valley, CA
    What user agent string website should I browse from the MCU? This one website I visited does not report the processor, or is not reporting the processor in the user agent string indicative of the Tegra 3 processor?
  10. P85_DA
  11. gmontem
    Castro Valley, CA
    The CPU is undefined. I guess the MCU2 has that declared in the user agent string. WP_20180713_14_15_20_Rich_LI.jpg
  12. P85_DA
    @gmontem that is a MCU1 :( if MCU2 it would say “intel” :(
  13. Lawsteve
    Lawsteve MCATDT
    Tampa, FL
    Mine was replaced (for the second time in three months) last week. I have a Dec 2016 P100D. Part number on the warranty invoice is : SERVICE MCU KIT - NORTH AMERICA 1 (1452455-00-C) . Per the “What’s my agent” site noted above, mine does not ID as intel, thus I assume it is a replacement with the older MCU.
  14. Jack Tripper
    Jack Tripper Member
    What is the part number for MCU2?
  15. rscott0
    rscott0 Member
    Massachusetts
    Just as an FYI, I just got my MCU replaced ("MCU not measuring supplied HVAC rail voltage properly"), something the service center noticed when attempting to do a coolant flush. It's MCU1 (based on teslatap.com/mcu which shows "Mozilla/5.0 (X11; GNU/Linux) AppleWebKit/601.1 (KHTML, like Gecko) Tesla QtCarBrowser Safari/601.1").
    The MCU1 part number on the invoice is one I haven't seen in this thread (it is in another): "SERVICE MCU KIT - NORTH AMERICA 1 (1458829-00-B)". This is for a 2014 Model S85.
  16. Tozz
    Tozz Active Member
    Tynaarlo
    There we go again. MCU1 cars _always_ get a MCU1 when they need to be replaced. You will _not_ be upgraded to MCU2
    MCU2 requires:
    - New wiring harnass
    - New IC (screen behind steering wheel, with MCU2 it is a second screen to the MCU, with MCU1 it is a separate computer)
    - New mirror assembly (has additional antenna's for 5G WiFi and Bluetooth)
    it is impossible to upgrade a MCU1 car to MCU2 without lots of labor and lots of new parts. Especially the new wiring harnass will require removal of _lots_ of trim pieces and will take a considerably amount of labor hours. Replacing a wiring harnass will also require extensive testing to ensure everything works, adding up the labor hours.
    • Disagree x 1
  17. Krash
    Krash Data Technician
    Intermountain US
    We don't actually know what an MCU upgrade will entail since we have not seen one. It is possible Tesla would support a wiring harness adapter, leave the old IC and skip Bluetooth.
  18. Tozz
    Tozz Active Member
    Tynaarlo
    I've said this elsewhere before, but I do not believe this will happen. It will create a technical and CPO nightmare. Lets say you upgrade your car to MCU2, but you skip bluetooth and 5G. And let me start by saying that Elon tweeted there are plans to do phone unlock in the S/X like in the M3 for cars with MCU2, see:
    Elon Musk says the Model S and Model X will soon get a long-awaited feature that the Model 3 already has
    Now, lets say you upgraded to MCU2, but you skipped the wiring harness and thus you do not have Bluetooth. Also, you do not have 5G WiFi.
    Now, both Bluetooth and 5G WiFi will have to be turned off in software. Otherwise you might just have very poor reception, causing issues (such as failed band steering on WiFi). This will require software changes in firmware, which will costs Tesla development time. Also, the Bluetooth phone key feature will not work for you.
    Now you sell this car to Tesla, and Tesla will need to sell this car as a CPO.
    Here is when the drama begins. Tesla will have to mention that:
    - This is a frankenstein car with a half-upgraded MCU
    - The car should have 5G WiFi, but its not connected, so its not working
    - Bluetooth unlock is not working, as the upgrade was half-baked.
    And:
    - Regarding your 'use old IC' comment: Tesla will have to add the possibility of using the old IC with the new MCU in their firmware, which will require additional testing for each release. It also adds additional complexity which, for Tesla, has absolutely zero benefit. 0.
    Effectively you have upgraded a fully functional car to a car with a faster screen, but with lots of features that are none functional. For Tesla it means additional complexity for future repairs, registration (as all these changes will have to be registered somewhere), etc.
    If I were Tesla, I would never let this happen. It creates a technical nightmare, both for Tesla (as it will need to disable modems in software, add firmware complexity) as well as for future customers that buy these CPO and expect things to just work.
    I can already imagine the threads here 'I bought a CPO and my bluetooth isn't working!', only to be told 'Yeah someone didn't want to do a full upgrade to your car in the past'. If I was the owner of that CPO I would not be happy.
    _IF_ (and that is still a big IF) Tesla will offer MCU2 upgrades, it will be a complete and functional upgrade. I'll bet a few bucks they will not perform half-upgrades.
  19. Krash
    Intermountain US
    You could be right. It will be interesting to see if Tesla has enough MCU1s for all the warranty claims and if not, whether it is cheaper to test and maintain a sort of MCU 1.5 or whether it is cheaper to retrofit all those cars to MCU2.
  20. Tozz
    Tozz Active Member
    Tynaarlo
    As far as I know all replaced MCUs are being repaired whenever possible and reused. Also, failed MCUs are not very common. Its mostly the screens or digitizers that have issues (yellow banding, bubbling, etc). Some MCU issues with worn-out memory chips, but those can be replaced and then reflashed.
    When Tesla does run out of MCU1's, I'm sure they will think of a solution.
