MCU1 upgrade - Radio and XM
Discussion in 'Model S' started by Zelectric, Mar 11, 2020.
  1. Zelectric
    Zelectric Member
    LNK
    Folks,
    I remember reading the day the news broke about the MCU1 upgrade, that a journalist or a poster posted that the old MCU1 cars with the AM,FM,XM radio could also buy the upgraded MCU2 radio module to keep FM and XM and only lose AM. As well as the part numbers required. I wanted to post this back to a forum but the document in my google drive is blank.
    The post was either here or some place like teslarati. Which now I can't find it. If anyone knows where I can get it let me know.
    My problem is I use XM a lot because I have a 10 minutes of my drive with 0 AT&T coverage.
    Tom
  2. realvvk
    realvvk Member
    Philadelphia
    May I suggest an audiobook? Just kidding :)
  3. patrick40363
    patrick40363 Active Member
    Cali
    When i read the article it states you lose XM. I will not be upgrading.
  4. Zelectric
    Zelectric Member
    LNK
    Here it is.... Post #1
    FAQ: MCU2 Upgrades
    I had to find the part number, then search the internet . :)
  5. Russell
    Russell Supporting Member
    Silicon Valley
  6. Zelectric
    Zelectric Member
    LNK
    I'd like someone to say they got the upgrade and purchased this as well... P/N w XM - 1143711-00-C.
    Oh and it worked...
    Let me know.
    thanks
    tom
  7. rjscoder
    rjscoder Member
    Ohio
    Got it. Did work. Lots of work though. You also need the cable that connects to mcu2 that's not included anywhere in your car, and tesla may not even sell it. Good luck!
  8. KalJoMoS
    KalJoMoS Member
    EETN, EST
    Does your setting survives OTA software upgrade?
  9. rjscoder
    rjscoder Member
    Ohio
    Yes it does
  10. ShawnA
    ShawnA Supporting Member
    Edwardsburg, MI
    Hi Rjscoder,
    Do you have a part number for the cable to connect the radio to MCU2???
    Thank you,
    Shawn
  11. cellphonechris
    Connecticut
    Aside from the cable, can you elaborate on what "lots of work" entails?
  12. tyson
    tyson Member
    IA
    The lots of work is the fact that the tuner is buried in the dash and not easily removed. Now if you want to you could just run the new cabling and zip tie the new one up under the dash but if you want it to be mounted the way it should be then you have a good bit of work to do.
  13. rjscoder
    rjscoder Member
    Ohio
    Unfortunately no part number as it's wrapped and bundled in the main body harness on newer cars.
    Here's what it looks like cut from the harness. 4 pin to 10 pin [​IMG]
  14. rjscoder
    rjscoder Member
    Ohio
    It's not that awful to have to run all new cables to the dash. You can remove the tuner, it took me about 20 minutes, it's just annoying. You have to have a low profile bit to get to the screws in the back. And then it just slides out.
    I took off 2 bolts from the bracket, and 4 screws from the tuner. This let me ease it down and out of the space.
  15. tyson
    tyson Member
    IA
    Is that an S or X? Mine definitely did not just slide out after removing those same bolts/screws. That was a 17 Model X.
  16. rjscoder
    rjscoder Member
    Ohio
    S. I've heard the X is quite a bit harder, that stinks
  17. tyson
    tyson Member
    IA
    Also do you have a pn on the harness/wiring? I need to swap mine out.
  18. wanche
    wanche Member
    Toronto
    why not just use radio app from your phone to stream FM/AM if needed?
  19. ShawnA
    Edwardsburg, MI
    Hi Rjscoder,
    Thank you. It looks like I might have another project this year...
    Shawn
  20. rjscoder
    rjscoder Member
    Ohio
