Mechanical issues
Discussion in 'Australia & New Zealand' started by Dborn, Oct 25, 2016.
  1. Dborn
    Dborn Confirmed
    Sydney, Australia
    I thought that it was time we had one of these here. Moderator, make this a sticky?
    With the warmer weather, i have been driving lately with the roof and windows open and aircon off. I have noticed a metallic clicking which is inconsistent, although today i finally worked out how to make it consistent. Low speed, light acceleration and deceleration repeatedly will produce the sound. I can only hear it with aircon off and windows open.
    So, went in to Tesla Sydney, and Gavin came for a ride. He agrees it is not normal and is in the drive train. So, it is booked in for next week when they will give it a proper once over.
    This is a heads up for you to listen out for an abnormal clicking, sounds like light metal, coming from the rear of the car. My car has done 27800 km odd.
  2. PJF000
    PJF000 Member
    Australia
    I know you said inconsistent but have you checked your tyres for stones stuck in tread or a nail in tyre.
  3. Dborn
    Dborn Confirmed
    Sydney, Australia
    Yep. Also, service advisor has heard it and believes it is in the transmission. Actually, tonight, it is now a mild thunk, as well. I am hoping this does not mean a new motor/ transmission. Although, if it does, it is going to be quick and relatively painless.
  4. Mark E
    Mark E Member
    Sydney NSW
    It's most likely a re-packing of the drive-shafts and a new washer - mine was done last week. 32,000km.
    Extract from the receipt below;
    "Corrections: Exterior NVH General Diagnosis
    Rear left hand side there is a clicking noise at low speed from standstill. Recommend to replace driveshaft lock nut and washer and apply lubricant.
    Corrections: Halfshafts - Lubricate at Hubs LH/RH
    Applied lubricant to halfshaft at hub."
  5. ShockOnT
    ShockOnT ⚡️⚡️⚡️⚡️⚡️
    Sydney
    It's not something as simple as the wind rattling the rear seat belt is it?
  6. Dborn
    Dborn Confirmed
    Sydney, Australia
    No regrettably not. The symptoms do sound similar to Mark E.
    Devvie goes in Thursday and I will report back after.
  7. ZTrekus
    ZTrekus Member
    Sydney, NSW
    Looking forward to hearing a follow-up on this.
  8. Dborn
    Dborn Confirmed
    Sydney, Australia
    Well, it seems mark-e is on the money. The issue is apparently the same as his. Retorqueing bolts on the drive shafts, packing with grease and a new washer. Apparently a relatively common problem and the subject of a service bulletin.
  9. Mark E
    Mark E Member
    Sydney NSW
    Since it seems to appear after about 30,000km if it recurs then it'll most likely end up as part of the annual service.
