Why not just use the UMC that comes with the car? Adding a 3ph 16A plug on the other hand makes some sense and people have done it with mostly positive results.A little OT but I've heard of people installing a standard 10A 240V plug onto the end of the HPWC. Is this reliable/acceptable and easy enough to DIY?
I hope that was a slab plus 10%.....for gst, although not sure who gets the half bottleHi guys - long time Tesla owner and I also happen to run JET Charge - just some thoughts from my own point of view:
1. We generally don't ask for photos to firm up quotes because inevitably only a small percentage of people can be bothered to send us photos, and it ends up being too difficult so they cancel. We therefore have to use our experience to quote a standard installation based on distance from switchboard.
2. All pricing, specs and details are submitted back to Tesla. This ensures that they have everything on record in the case of warranty repairs etc - makes it a bit easier. Also makes us accountable back to Tesla for everything we do.
3. When we do apartment installs, we normally end up negotiating with the owners corp, attending meetings etc. Doesn't happen with every installation, but does with most. Also, for many apartment installs, we need to use a monitored system like Chargefox, which requires a new charging station, and that's why it can cost more, because there's literally another charging station in there (the Tesla unit can't be connected to the internet). I know a lot of people just want to install a charger with an in-line meter, then deal with it later, but unfortunately that's not really scalable for the building and I think those days are probably numbered.
4. Also need to make sure that your installer uses Type A RCD/MCBs (rather than AC, which is the norm) to comply with AS/NZ 3000, and that they size the cabling appropriately.
5. Cheapest install I've heard of is a slab of beer, charging station installed right next to the switchboard. Cannot confirm or deny that it was offered by us
@timpoo Can you explain what you mean in point 4. Not a big fan of TLAs. (Three Letter Acronym)Hi guys - long time Tesla owner and I also happen to run JET Charge - just some thoughts from my own point of view:
RCD = residual current device@timpoo Can you explain what you mean in point 4. Not a big fan of TLAs. (Three Letter Acronym)
The Tesla HPWC is rated as IP55 so is fine to live outside.Mainly because it will be almost a permanent outdoor fixture. Is the UMC weatherproof? Our powerpoint is indoors so I would just be feeding the cable through a hole in the wall.
