Merit Builder Tesla Charging
Discussion in 'Video' started by TEG, Jul 2, 2010.
Tags:
  1. TEG
    TEG TMC Moderator
    #1 TEG, Jul 2, 2010
  2. tdelta1000
    tdelta1000 Active Member
    South Florida
    The solar carport is interesting. here's a PDF on the product but I still have a few questions.
    Meritbuilders Solar-Carport
    What are the max wind loads?
    How long will the panels last before any major work needs to done on them? What material is the port made out of?
    Will there be any special permiting needed to construct the unit?
    What happens when an EV is not charging?
    Is the product storing power or can it store power with a few changes?
  3. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    Unless this thing has power storage, it doesn't strike me as being very useful. During the day my car is usually nowhere near the charger. It gets charged at night.
  4. TEG
    TEG TMC Moderator
    When you look at the product specs PDF you can see it says "Grid-tied system".
    So it would feed power back to the grid during the day (used by others who are busy with their daily power demands), and then you would charge from grid power at night. Many power companies will pay more for daytime power you give them than they charge for night time power since daytime demands tend to be much higher.
  5. ChargeIt!
    ChargeIt! Member
    The Grid is the Battery ! :smile:
  6. Doug_G
    Ottawa, Canada
    Okay, fair enough.
    In that case, having the cars park under it is just for show!
  7. vfx
    vfx Well-Known Member
    CA CA
    It's exactly the kind of show we need everywhere. Having electric cars parked under solar panels is a great visual link to show they can run without burning anything.
  8. tdelta1000
    South Florida
    I would agree with Doug on this point. What if a person lives in an area where they may not be tied to the Grid or they may chose to live off of the grid then having some type of storage would be nice.
    I like the fact that there will be a ROI because the system can be tied to the Grid.
  9. edo
    edo Member
    It also does keep the car cooler in the summer... so there will be less AC losses when you leave.
  10. ChadS
    ChadS Petroleum is for sissies
    I'd like to expand on this point a bit. While it would be really cool to charge up while the sun is shining and get real sunshine-generated electrons in your battery, electrons are fungible. While it is great that some electrons are sunshine-generated, it doesn't really matter whether those particular ones end up in your car or not. The best use is to feed them to the grid in high-demand hours (usually daylight, fortunately when the sun is shining!), when you can help the grid keep from having to use its dirtiest sources to satisfy that last bit of load. Then you can pull the electrons you need at night, when there is excess capacity.
    You lose out on the satisfaction of saying your car contains real condensed sunshine; but you really do more to clean up the whole system. (And in most states with most utilities, as TEG noted, you come out ahead dollar-wise as well).
    Of course having storage is still useful if you are not connected to the grid, or if you want to be prepared if the grid goes down.
  11. TEG
    TEG TMC Moderator
    And someday in the future, when V2G is ready for primetime, your solar panels *AND* your EV battery will supply your neighbor's air conditioners during the day, and then the EV battery will be recharged at night to replenish energy used for both driving and balancing the daytime needs of the grid.
  12. meloccom
    meloccom Moderator Aus/NZ
    Sydney Australia
    #12 meloccom, Jul 16, 2010
    Aerovironment are already working on a home charger with on board battery storage.
    AV Home Chargers
    Scroll down to "Home Charging Appliance"
    This thing will allow you to take advantage of night rates and efficiencies and allow you to charge at any time.
    Hope they can make it work at a reasonable price.
