Metal Key fob cover
Discussion in 'Model S' started by r0bgj, Aug 3, 2018.
  1. r0bgj
    r0bgj Member
    Salinas
    Hi guys,
    I've done some searching and found results on key fob covers but not the metal ones. I got one and it seems to block the signal almost completely. Most of the time it wont work. Has anyone found a way to make the metal key fob cover work or found a particular one that works 100% of the time?
  2. Jhelin
    Jhelin Member
    Sweden
    A metal fob cover would always block most of the RF signal the key uses to function so there's no way to make it work.
  3. pkodali
    pkodali Member
    Sacramento
    We have them for our model X keys but we have never had a problem. They have a little cut out in the front where the RF emitter is
  4. boaterva
    boaterva Supporting Member
    Northern Virginia, USA
    What’s the question? You want a fob cover that’s metal for appearance or a metal cover that does block the RF for security?
    For appearance I use the silicon ones from Abstract Ocean (less slippery in your pocket) and for security at home a faraday bag from Amazon.
  5. zwede
    zwede 2013 P85+
    Plano, TX
  6. P85_DA
    P85_DA Supporting Member
  7. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    Is it metal or looks like metal.
    Metal blocks the flow of RF, not even Elon can get by that law
  8. P85_DA
    It’s metal ..works fine
  9. pkodali
    pkodali Member
    Sacramento
    They have a hole in the front where the antenna is
  10. r0bgj
    r0bgj Member
    Salinas
  11. r0bgj
    r0bgj Member
    Salinas
    i got this one from amazon. i got this one because its red and wanted it to match my car. i also liked that it has the cutouts for the windows. you'd think this allows more signal to reach the car but it sucks so much. i wonder whats different between the one you guys got and the one below. besides the window color and the cut out, they look the same.
    https://www.amazon.com/gp/product/B0778KQKTC/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
  12. P85_DA
    They all probably come from the same Chinese manufacturer lol mine has windows cutout as well I don’t see difference in range between this and the silicon cases
  13. whitex
    whitex Well-Known Member
    Seattle area, WA
    Tesla touchup paint? ;) Get it in silver, paint with touchup paint matching your car.
  14. P85_DA
    Exactly ....
