Mid Range trip report - 268 Wh/mi.
Discussion in 'Model 3' started by pipestem, Feb 17, 2019.
  1. pipestem
    pipestem post-newbie
    Center of the Universe
    Weekend trip to from Durham, NC to Athens, GA. Start temp 44F (rain) ; mid trip temp 70F; end temp 39F (more rain). Not much elevation change. 90% on Interstate 85. Frequent use of defrost, some heat.
    717 miles, 192 kWh, 268 Wh/mi.
    No waiting at superchargers in Charlotte, Greenville, or Athens.
    The car eats miles like candy. Great, great road car. Amazingly good highway efficiency compared, ahem, to some other EVs. I love this car.
    • Like x 5
    • Informative x 3
  2. intenost
    intenost Member
    Acton, Massachusetts
    Thanks for the report. Pretty efficient, 18" aero wheels? I'm at 999 miles on my MR delivered 12/12. All relatively short trips so far, looking forward to my first real road trip!
  3. pipestem
    Aero covers were off - I really do like the base wheels. So nice to be able to do that. (former leaf owner here)
  4. voip-ninja
    voip-ninja Give me some sugar baby
    Colorado
    You don't state what your average speed was which is probably the overwhelming weighting factor on efficiency on the highway.
  5. pipestem
    Well,as I said it was 90% interstate, so you can guess it was probably ~ 90% 70 mph + 10% 30 mph. I think the beast does very well maintaining efficiency at speed. I ran some tests earlier this month at totally steady state, no heat, no traffic, cruise control run at 70 mph, about 50F, and I was getting about 225 kWh/mi. My 2754 mi lifetime is 256 kWh/mi. I'm quite happy with Tess.
  6. Sandiegodoug
    Sandiegodoug Member
    SAN Diego
    Here’s my long range rwd over course of 13 months. All types of driving
  7. pipestem
    Ahh, you are quite a bit more efficient than me. I need to control that right foot !
    I wish Tesla would keep the lifetime metrics and show them on that same panel. Also wish they would keep and show the kWh/mi, temperature, and elevation graphs for each trip. And for lifetime. And make that history and all history available in my Tesla account. And let me download it. And....
  8. Unpilot
    Unpilot Sell order in at $3999.99
    A Coast
    I'm...um...a little over that!
  9. SigNC
    SigNC Active Member
    NC
    He's also in san diego which helps a lot :)
  10. KKman
    KKman Member
    N. Cali
    My first 10k... Am happy for the efficiency! Even better than the official EPA
  11. Hank101
    Hank101 Go Tigers!
    Greenville, SC
    I am trying to determine how I could make the MR battery version work for my commute, and I know that this is a very subjective question, but what would be "typical" single charge range (miles) for the MR battery size, if accounting for max and min routine charge level (80%-20% ???).
    General estimate for absolute best case (garaged, plugged in, weather conditions, speed, ect...)
    General estimate for absolute worst case (non garaged, cold soaked, weather conditions, speed, ect...)
  12. pipestem
    I think most of us charge to 90% which is 237 miles right now, at standard rating of about about 240 Wh/mi. Dropping down to 10% gives you about about 208 miles of range in the bast case. I don't know your location and weather, but there are several reports on the board about the winter loss. I don't want to speculate for your situation.
  13. derekmw
    derekmw Member
    San Diego, CA
    I was doing 80% but Elon has stated that 90% is fine and have since then changed the charge limit to 90%. I can't imagine many people who need more than the 200 +/- range for daily commuting.
    If you want things in mi/hr for charging, my work charging stations are 30A/204V and usually shows charging at around 24 mi/hr.
    At home, I use the first gen mobile charger that chargers at 40A. I have never seen how fast it charges but obviously a bit faster than the above ones (I charge after midnight)
  14. Runebane
    Runebane Member
    Visalia, CA
    The biggest questions are how long is your commute (round trip, plus any extra stops you may want to make) and are you going to install a charger at home and charge every night?
    If you have a long commute like I do, the winter effects won't be as harsh as multiple small commutes. So say you have a 120 round trip commute like I do. You'll lose, depending on how cold it gets, anywhere from 10-25% because your car will have time to warm up the battery. That plus a charger at home would make it easily doable for you.
    However, if you don't have a charger at home and want to make multiple smaller commutes, you'll be at the SC a lot because you'll lose closer to 40% range.
  15. novox77
    novox77 1.21 Gigawatts
    NH, MA
    Coming up on a year of ownership. LR RWD trim. 13k miles, just over 200Wh/mi.
  16. No42
    No42 Member
    WA
    My 7000 mile avg is 287 wh/mile. I have LR RWD 18" wheels.
    How you guys manage to get <240 wh/mi.
    Wondering if something is wrong with my car.
  17. Jedi2155
    Jedi2155 Model 3 has Arrived.
    Diamond Bar, CA
    TeslaFi my friend :)
    Referral code: Jedi2155
    Look at all the fun details your missing!
  18. Jedi2155
    Diamond Bar, CA
    Thats even higher than mine! I'm at 277 Wh/mile lifetime ~7400 miles . It's also possible you're just using a lot of heat, you have a giant lead foot and don't use regen (remember try not to brake and rely on the regen more often), or your car is really busted.
  19. Aellinsar
    Aellinsar Member
    Ohio
    That is really impressive! I'm at 10k miles and have an average of 268 Wh/mi. I was ~240 average before winter started. I use regen al much as possible and keep the cabin fairly cool (64-66°F), but even in perfect fall weather I was never able to achieve a 200 Wh/mi average.
  20. derekmw
    derekmw Member
    San Diego, CA
    Interesting to see so many trying to achieve these low wh/mi. I never try to achieve keep it low. I drive it normally, accelerate fast when I feel the need, and enjoy the car whenever I can. I will say though, I do take advantage of regen and rarely have to touch the brake pedal.
    Are you guys trying to do this to save on electricity used to charge the car? Or just to see how efficiently you can drive it? When I was in my Leaf, I used to do everything to drive it as efficiently as possible, but that was because the range was so low, I had to do it.
