Yes, I just saw that; there are two. I guess I didn't see this small anomaly in the picture.Nice, very clean!
One question. Are there 1 or 2 PWs? Can't tell from the angle.
And are you going to run it to "test" it? (Don't answer this!!!)
Nice, very clean!
Yes, I just saw that; there are two. I guess I didn't see this small anomaly in the picture.![]()
They had to drill a hole in the front left side of that back PW, connector about 1" that looks like can flex and then they apply spacer covers over that gap on three sides.You have to love that Tesla cares enough to pre-drill connector holes so 2 PWs installed side-by-side have no gap and appear as one. Again, that is one clean install!
Yep, this is year 9 of operation.Since he already has pre installed (and presumably permitted ) Solar, ...
Oh, this Gateway has the "reset" hole through the panel inside. Gateway 2?
But now I have questions I thought I would remember from past posts.
I don't see the "customize" tab on the iPhone app or how to get there. Hit everything and not there.
Also, I cannot bring up the IP address that the crew used, it seems and the Gateway doesn't show on the wi-fi map.
The range extender was for the solar panel current sensor.
And I need to set it up for notification when grid is down in case I need to reduce house loads on extended grid down.
I guess, looking at the Tesla video at their web site, it is below backup history. I guess it will come later.
Thanks. It went over my head when I was looking at that list of explanations where it is.Some stuff just takes time to show up.. like 1-4 days or so. to connect to the gateway, you would connect to the SSID that its broadcasting and follow the instructions that tesla has for connecting locally.
Note, the amount that you can change things when logged in locally is very minimal.
I posted a link from tesla's site in another thread here recently that talks about logging into the gateway, ill re post it here for you
EDIT... here you go Connecting to Tesla Gateway | Tesla Support
Should be in the app - under the "customize" option for me (Android app, but I assume same.)Well, I searched the site for how to find "storm watch" setting and turn it on but no luck
Is this in the Gateway setting or can I do it from iphone app?
Not critical here in Monterey but...
Thanks. That is what I thought as well but not there, not under that title anyway.Should be in the app - under the "customize" option for me (Android app, but I assume same.)
Thanks. This too it seems. The "customize" feature is there but since it is below "backup history" at first I didn't know to look for it by pushing up on that app page. It could have been there at install or not; it is there now.It comes "later" (some random amount of time, measured in days, not weeks, after install).
You will find lots of interesting stuff hidden in the app when you scroll. For example when you select one of the objects like Solar and it displays the graph scroll up to see hidden gems. You can even capture the data and use it for other purposes.The "customize" feature is there but since it is below "backup history"
@charlesj thanks for posting this. I used it to check on the status of our solarglass roof inspection. They ended up pushing it back a week, but no one had contacted us. So I called the number (this is support number for cars and I guess everything), selected energy products, and the solarroof and got right to a someone. He looked us up and read me the information about the a permit update they needed to make, and ensured the inspection team had our number and would contact use before coming out on the 28th.Well, had a great experience with tech support this morning, this minute.
I called about the battery frequency adjustment and storm watch not on app yet, five days.
The gen was great. Listened and said they will take care of it. In a few minutes on hold he gave me a case number for both.
Great experience today.
In case one is interested I called # 1-877-798-3752-3-3-1 (the 1 is for power wall)
Another number posted before was busy right off the bat.
