Miles / kWh window on Model 3
brjr
77
9
worthington ohio
There is a little window in the bottom left of the screen that is labled 'Trip A'. It shows mileage and watt hour consumption since 'Trip A reset' . When the car is NOT being driven, does this measure include power consumption while parked?
Why is 'wH/mi' so high when the car is first started up, in the range of approx 450 and then lower after driving around town?
Reactions: Transformer
derotam
825
702
Oak Hill, VA
No, it does not count power used while in park*, only while in a driving mode(Drive, Reverse, or Hold).
*You can get energy spikes immediately after going into drive and driving because of the timing of recording of energy usage by the car. I don't know what the timing is, but for example, if the car logs every second to the Trip meter you could have up to almost a second worth of Parked energy usage get accounted for in your Trip counter. Because this is such a short window of time, it averages down VERY quickly as you drive.
Reactions: dhrivnak
GtiMart
970
810
Quebec City, Canada
I think your initial acceleration in a short period as well as full-on heating or conditioning are high power demands. In the first few meters of driving, these are extremely high for the distance driven. As you drive around these average out on your drive.
brjr
77
9
worthington ohio
Thanks derotam.
brjr
77
9
worthington ohio
Pre-conditioning the cabin helps to reduce initial big power hit. (heat or A/C)
I was wondering about the fan/vent running after i exit my car, even in my garage which has moderate temperature compared to outside. I would prefer not to have that running so much. Would it hurt the car if i disable it?
derotam
825
702
Oak Hill, VA
It is running for a reason, specifically to dry out the A/C system to prevent the dreaded "Smelly A/C". Many ICE vehicles run fans for a bit after turning off the car for the same reason.
Dec 26, 2019
156
88
Silicon Valley
That's a great feature, but my fan was running for a while after driving without A/C.
I opened the app and tapped TURN ON CLIMATE then TURN OFF CLIMATE. The fan turned off right away. Maybe it was a coincidence. I'll try it again next time.
brjr
77
9
worthington ohio
Thanks for the info about the ac mildew avoidance. That is important. And i usually turn of the climate anyways. I will make a point of leaving it on during warm weather to dry out the ac. Appreciate peoples' experience and advice.
derotam
825
702
Oak Hill, VA
Were you in manual control or in Auto? Just cause you weren't running the A/C for cool air, if you are in auto the A/C might still be running for de-humidification purposes...even when using the heat.
brjr
77
9
worthington ohio
I leave the AC on (icon highlighted) to keep humidity down but i turn off climate (power icon) when i exit the car. Should i just leave it on and assume the system will shut down appropriately in a short while?
Dec 26, 2019
156
88
Silicon Valley
My understanding (please correct me if wrong): When you exit the car the climate turns "off" in the sense of no longer heating/cooling/circulating air, regardless of that power button, and automatically runs a fan to dry the A/C coils as long as needed, and may run fans automatically to manage battery temperature as needed. The app is the only way to start/stop climate control for an unoccupied the car, and I'm chalking up the case with the fan running in the garage as a bug.
Reactions: GtiMart
