Minor issue: s this a scratch or some black residue?
Discussion in 'Model 3' started by Sneakerhead, Aug 1, 2018.
  1. Sneakerhead
    Sneakerhead Member
    So cal
    Has anyone else have this black residue/scratch on the paint?
    I tried using damp microfiber towel to remove and several alcohol pads. It wont remove..i cant tell if its sunken or lifted its just black.
    This was spotted by my delivery specialist and he told me that he will remove it but did not and I forgot to followup on it due to the fast education of vehicle setup.
    Should I just live with it? I love the car so much! Everything is pristine but that...
    Emailed the deliver specialist but did not hear a reply at this time. 20180801_163043.jpg 20180801_163032.jpg
  2. Glamisduner
    Glamisduner Active Member
    Escondido, CA
    looks like a paint chip to me.
  3. outie
    outie Active Member
    SoCal
    Second picture looks like a little bump, so it's some kind of residue. Have you tried using your fingernail? Wax?
  4. fseir
    fseir Member
    Honolulu
    Try a clay bar. If it doesn’t lift, and feels smooth, it may be a paint defect under the clearcoat.
    That would drive me crazy, but I’m super ocd.
  5. ilg
    ilg Some guy on the Internet.
    Maryland
    Looks like a bit of tar to me. I'd try bug and tar remover.
  6. brobinson
    brobinson Member
    Ohio
    Try Goo Gone
  7. novox77
    novox77 1.21 Gigawatts
    NH, MA
    try isopropyl alcohol first, since you likely have some as part of a first-aid kit.
    after that, I'd try mineral spirits, which is the base for most of the fancy commercial products out there.
    neither will harm your paint.
  8. eSpiritIV
    eSpiritIV Member
    Portland, OR
    I feel like ive seen this on other cars also. It may be the sealant used to set the windshield. Dont think its a paint defect,
  9. mberta74
    mberta74 Supporting Member
    Rochester Hills, MI
    That same issue was on my Model S, it happened to be adhesive from one of the panels of film they put on the car for shipment or build, I recognize that patch, mine spot happened to be on the top of the car, I'd was it and it would never go away, it just returned... A local paint shop removed it with a goo gone adhesive remover
  10. mberta74
    Rochester Hills, MI
    Looks familiar
  11. chronopc
    chronopc Active Member
    I have a similar situation on my driver side door and the SC said it's a contamination that occurred during the painting process. They offered to send my car to a body shop to get the door repainted.
  12. Sneakerhead
    Sneakerhead Member
    So cal
    Thank you for your responses. I will try the goo remover. Yes Ive used fingernail quite firmly and was unable its pretty locked in.
  13. chronopc
    Can you tell if it's under the clear coat or not?
  14. Uncle Paul
    Uncle Paul Well-Known Member
    Canyon Lake,CA
    Your finger nail will tell you if it is a raised smudge or a scratch.
  15. Sneakerhead
    Sneakerhead Member
    So cal
    Well..this forum is filled with geniuses. Thank you guys for the suggestion. Goo gone and some scrubbing with microfiber towel worked well! No scratches observed.
