Minor vibration/shaking at speeds greater than 70 MPH
Discussion in 'Model S: Driving Dynamics' started by wres2345, Jun 10, 2017.
  1. wres2345
    wres2345 New Member
    NYC
    I've had the car for about 6 months, and it's fun, beyond fun, actually. But recently, I noticed a slight shimmering or vibration at speeds over 70. Sometimes less, sometimes more. Driving performance doesn't seem to be compromised, but it's definitely not as smooth as before. It's not nearly as noticeable as trying to go 70 with Valet Mode on, and I haven't hit any potholes, so I'm not sure what's going on. I hesitate to take it to a dealer, only because last time I did, it took forever to get the car back. Any suggestions?
  2. gaswalla
    gaswalla P4201/85/airsusp/pano/19i
    San Diego
    Tire balance?
  3. KidDoc
    KidDoc Supporting Member
    College Station, TX
    Get your tires balanced.
  4. Navsarin
    Navsarin S100D Red Rocket
    Canada
    Tire balance. If that doesn't work, get them to spin your actual rims. especially 21" as they are prone to damage on rough roads. Failing which it could be any number of issues with suspension, wheel bearings etc.
    Always start with tires...
  5. NoMoGas
    NoMoGas Member
    Los Angeles, California, United States
    I had this... one tire was slightly out of balance
  6. Yaozers
    Yaozers New Member
    Mass
    This happened to me when I went above approximately 50 mph. The speed when the vibrations kicked in wasn't constant. The vibrations dissipated when I was trailing another car/truck. It felt like it had something to do with the wind. I checked wheel alignment, that wasn't the problem.
    From reading online, it sounded like I had a problem that others had: the front bumper was causing the vibration. The bottom of the front bumper would give too much when you squeeze it softly by hand. Tesla service installed a foam and that fixed it. No more vibrations.
    The vibrations were very subtle in the beginning. I definitely just thought it was the bad winter roads. But it got more and more noticeable after about 4 months. If I were you, I'd squeeze the bottom part of the front bumper. If it allows your hand tosqueeze it, then that's possibly the problem
  7. OilSucks
    OilSucks Member
    Northern California
    Had this on my old ICE vehicle as well. It's usually a combination of your tires needing to be balanced/rotated or alignment.
