minus 20 deg. celcius
Discussion in 'Model S' started by NielsChr, Feb 7, 2012.
Tags:
  1. NielsChr
    NielsChr Member
    Denmark
    Right now the temp is minus 20 degrees Celsius outside in Denmark, both in Norway, Sweden and some placed in the US/Canada temp will often get below a comfortable. temp.
    I assume Tesla should work well below that - anyone who have seen the beta who know how the heat is transported to the back seats.
    most premium cars have a air flow to the back seats to maintain a decent temp in the car.
    This picture is from a another site regarding a used VW, and shows a Passat witch have been drinking to much water...But it also shows the air pipes below the front seats - these transport hot/cold air flow to the back passengers
    Have anyone noticed any similar heating to the back seats passengers in the beta? - any pictures ?
  2. doug
    doug Administrator / Head Moderator
    SF Bay Area
  3. gmontem
    gmontem Model S P01707
    Castro Valley, CA
    Are those recessed seat belt locks and chair arms?
  4. doug
    SF Bay Area
    Umm, yes to the seatbelt locks. Not sure about the arm rests. The back seat is pretty much a bench, so they're no loss in head room if you have to sit b*tch since there's no transmission tunnel/center hump.
    Here's another photo:
    (Norbert - Photos from Sunday, October 2, 2011 (Model S event))
    Anyhow, for the purposes of this thread, you can see the vents that come out of the front arm rest to provide air to the back seats.
  5. Doug_G
    Doug_G Lead Moderator
    Ottawa, Canada
    The Roadster has a 3 kW heater, but it's not exactly toasty at -20C. Hopefully the Model S will do a better job... I believe they said it's a heat pump rather than just resistive heaters?
  6. Lyon
    Lyon 2016 S P100DL, 2016 X P90D
    Eugene, Oregon
    Yes, the heat and AC are supplied via HVAC. Unfortunately, HVAC doesn't do a fantastic job when it's REALLY cold out (or at least that's what I was told in regards to residential heating/cooling).
  7. cinergi
    cinergi Active Member
    MA
    My CA (Dan) rides with the HVAC team to work every day and I've given him a LOT of feed back that he's been passing on to the team. So I know they're at least aware of the issues we have with the Roadster.
  8. Eberhard
    Eberhard #421 Model S #S32
    Germany
    #8 Eberhard, Feb 8, 2012
    I have good experience with the directed heat pipe, bringing the warm air to the drivers feet. Don't forget to block the passengers outlet.
    But still the best is the heated seat-cover used to keep my feet warm.
  9. Discoducky
    Discoducky Happy owner of a P100D X and a brand new 2021 M3!
    Seattle
    I wonder how much heat will dissipate into the cabin from the battery? I hope TM will encourage/allow this on very cold days.
  10. stopcrazypp
    stopcrazypp Well-Known Member
    Given the battery has its own liquid cooling/heating loop (and thus is likely very well insulated), I would expect virtually none. It's better to keep the battery well insulated so that you don't see as big a temperature swing (esp. the resulting voltage sag) from ambient temperature changes. One of the biggest problems in winter for most BEVs is because of voltage sag from low battery temperatures (which affects the range many times more than the heating requirements for the cabin).
  11. bolosky
    bolosky Member
    There's not going to be that much power there to dissipate. The whole drivetrain is supposed to be ~85% efficient. If you assume that the losses are evenly spread between the battery, inverter and motor then 5% of the power draw turns into battery heat. When you're cruising, this probably means < 1kW battery heat. You need several times that power to heat the cabin.
  12. Discoducky
    Seattle
    That's a great point, it would appear that even on moderately cool days (10 degrees Celsius) that the battery will need to be heated with such a small amount of waste heat being generated.
  13. Doug_G
    Ottawa, Canada
    Also there is an issue of basic thermodynamics. In order to get heat to flow you need a temperature difference. I don't think my Roadster's coolant has ever been over 41 degrees C.
  14. eledille
    eledille TMS 85 owner :)
    Oslo, Norway
    #14 eledille, Feb 9, 2012
    That used to be true, but things have improved. My HVAC is producing a lot of heat even when it's -24 degrees C outside, which is the coldest we've seen since we installed it last winter. The manufacturer claims it works well down to -35 C.
    Correction: The manufacturer claims it works well to -25, but practical experience in Norway indicates it still works well at -30 C.
  15. Lyon
    Eugene, Oregon
    That's great to hear! I doubt that I'm going to be driving my Model S around in temperatures that low, but it's gotta be able to keep me warm below freezing.
  16. KBF
    KBF Model X owner (formerly Cdn Signature Model S)
    Steinbach, MB, Canada
    When it hits - 35C we stop BBQ' ing outside in Manitoba, but we still have to drive to work. Of course, that's also why we have electric block heaters - I don't see any serious issues unless you let the charge get really low and don't plug in at work.
  17. neroden
    neroden Model S Owner and Frustrated Tesla Fan
    Ithaca, NY, USA
    Last I read, heat pumps start getting less efficient than resistive heating around -20 C and below, but will still work down to significantly lower temperatures. I don't remember the exact reasons or numbers.
  18. eledille
    Oslo, Norway
    #18 eledille, Feb 15, 2012
    That's exactly what I meant when I said "used to be true". Our HVAC is clearly much more efficient than resistive heating even at -24, at that point it's still blowing a huge quantity of very warm air. Its output is actually much warmer at -24 than at -15, simply because at -15 full power isn't required to maintain 20 C indoor temperature. I'd estimate it replaces at least 2 kW of electric heating and it saves stacks of firewood to boot. Max consumption is 600 W. The manufacturer claims it delivers more heat heat energy than the electricity it consumes at much lower temperatures than that, and it's not enormously expensive either. I think you can get even better models now.
    Condensation releases heat, evaporation absorbs heat, and you can change the boiling point of a substance by altering the pressure. The heat pump uses a combined pressure/vacuum pump and a valve to create a partial vacuum in the outside evaporator and high pressure in the inside condenser. That causes the refrigerant to cool to whatever boiling point the pressure dictates, -40 or so, as a part of it boils after having passed through the valve into the low pressure evaporator. The rest of the refrigerant then evaporates while absorbing heat as it flows through it. The refrigerant then passes through the pump into the high pressure zone, where it becomes hot due to the compression. The boiling point is also much higher at the higher pressure, +50 or so, so it becomes liquid again in the condenser while releasing the heat that was absorbed earlier.
    The reason for the falling efficiency at lower temperatures is that the pump must perform more work when the temperature differential is larger, as more vacuum and higher pressure is needed to evaporate and condense the refrigerant. When more heat from the pump is lost in the evaporator than the small amount of refrigerant still being moved can transport, you are losing energy compared to resistive heating.
    I believe the recent performance increase is due to inverter controlled brushless pump motors, digitally controlled release valves which allow precise control of pressure in both halves of the loop and new, better refrigerant (R410A).
    This doesn't mean that Model S' HVAC can do the same, of course, only that it's possible. Also, there are much tighter space constraints in a car. This is the model we bought.
  19. VolkerP
    VolkerP EU Model S P-37
    Germany
    thanks eledille for real world description & theoretical background. One more thing to add:
    Performance of heat pumps is measured in a dimensionless number named COP. Top notch residential heat pumps come with a COP of 4, meaning it uses 1kWh of electricity to extract 3kWh of heat from the (outside) heat source and transform it into 4kWh heat at desired temperature. The COP depends on input and output temperatures and varies with season, thus a formula is used to calculate a year-round average value.
  20. dpeilow
    dpeilow Moderator
    Winchester, UK
    Who was it said here they also use the ground as a sink to store heat from summer months to use in the winter?
    I was also going to say that some Japanese manufacturers are claiming a COP of 5, but eledille has one.
