Tldr: funky charge port behavior? Change the fob battery
Model Xwas fine last night. Plugged in wall charger this morning at 36% in 50°F garage. Ring lights flashed briefly green then white. Removed unlocked charger and closed the port door manually and also again from the touchscreen but both times it just reopened spontaneously. Drove the car down the driveway and back with the charge port door open. Various levels of reset did not fix the problem as the charge port door opened again moments after repowering.
I recall reading somewhere on this forum (that I have not been able to find) someone had a similar problem and the culprit was the key fob sending a persistent signal. In my case the fob and the charge port behaved normally after changing to a fresh fob battery. The second less-used key fob did not cause this problem which helped locate the trouble.
I did not try to unlink the key fob—that would’ve been next. Service was anticipating a service center visit for a new fob since reprogramming which cannot be done by mobile service. Fortunately there was an easier fix.
