Mobile battery pack swapping?
Discussion in 'Technical' started by GJMcManus, Jul 31, 2013.
Tags:
  1. GJMcManus
    GJMcManus Member
    Kansas City
    I know swapping is possible with fancy robots to accomplish it in 90 seconds. Would it be possible to manually remove and replace the pack?
    Are any specifics known about battery temp control lines? With the automated change system what about all the connectors? Could the battery that is removed be charged out of the vehicle?
    Any help or pointers would be greatly appreciated..
  2. bollar
    bollar Disgruntled Member
    Southlake, TX
    It's certainly theoretically possible, since it's done at the service centers, but it's not easy. The folks at the SC say the battery's weight on its own makes it difficult to maneuver around to complete the installation.
  3. GJMcManus
    GJMcManus Member
    Kansas City
    As the idea guy for an attempt at breaking current EV cross country record. I am trying to explore every angle not only to beat it, but smash it.
    One of my many ideas is use a flat bed trailer equipped to handle the weight of raising and lowering the pack and still allowing access to the necessary fasteners.
    This way we can use a smaller generator to charge depleted pack to full charge while traveling to next swap point.. Hopefully, it will allow under 30 minute exchange and take advantage of 3-4 hour drive/charge time..
  4. bollar
    Southlake, TX
    The truck with integrated lift sounds like a good idea. The two questions I would want answered:
    1. Is the battery "mated" to the car? e.g., do you have to program the car to take a new battery serial number.
    2. Is topping off coolant necessary with a battery swap. I have only seen disconnected batteries twice, and there was some spillled coolant around the quick release hoses.
    I think in another thread you were considering how to deal with DC fast charge, which is something else you'll have to resolve.
  5. GJMcManus
    GJMcManus Member
    Kansas City
    I thought it might be better to separate the threads and issues..
    With 3-4 hour drive/charge time makes charging issue a little more manageable. Even though it adds another layer of complexity and more points of failure..
