Mobile Charger stuck in Topfit Charger Hook
jbrady3324
106
96
Chicago
I just got the topfit hook, took it out of the box and put the charger in (the notched latch inside). I am completely unable to get the charger out. Is there some kind of trick or do I have a defective hook? Do I need to mount it to get it out? I am about to break it to get it out!
BluestarE3
4,083
5,153
Norcal
I mounted it, same issue. The charger is really stuck and I have NO IDEA how to get it out. Total disaster
I don't have one, but does it work the same way as with the Tesla cable organizer where it just hooks onto the notch on the bottom of the charging wand? If so, just lift up the wand to clear the notch and pull the wand out. Based on photos, the wand is stowed in a more horizontal orientation than with the Tesla equivalent, so maybe you have to push in slightly and lift up at the same time to clear the notch?
Reactions: jbrady3324
BluestarE3
4,083
5,153
Norcal
I ended up using a knife to pry it out. I think mine was defective. It shouldn't be that hard!
The Tesla version is the opposite: Bump the wand and it'll fall out of the cradle. I used to coil the charging cable around the cradle in large loops and the wand would land on the garage floor (not good) if it got dislodged. Now I coil the cable in tighter loops and the wand would just dangle mid-air if it got bumped.
BluestarE3
4,083
5,153
Norcal
One thing to add: Don't make the last loop TOO tight or else the wand won't stay in the cradle.
