Mobile charging for Australia
Mark E
860
176
Sydney NSW
Do you mean single phase 15A? If so the charger comes with a 10A plug, so you may need to modify it.
That won't help. The UMC that comes with the car has a small 'tail' that contains the 10A plug and some coding to tell the charger that it's a 10A plug. Tesla haven't told us when the 15A version will be available, but it'll be a tail to plug into the UMC. On a brighter note, a 10A plug will fit into a 15A socket and should work.
If you want to spend the money, you can get an after-market portable charger that will go as high as 32A 3 phase.
paulp
2,675
1,215
Adelaide, Australia
If the coding tells the UMC that it's a 10A plug then going into a 15A socket likely won't give more than 10A?
There is a 3phase plug available from tesla for the UMC, (mine came with one) however there are a lot of different 3 phase plugs around, so the chances of a good fit are reduced.
lennier
605
101
Melbourne, Victoria, Australia
Really, there's an Oz 3 phase plug for the UMC available already? I'm surprised there hasn't been more about it on the forum. I'll have to talk to Tesla..
And yes there's no way for the UMC to know that it's plugged in to a 15A socket, the 10A adaptor is hard wired to report a 10A pilot current to the car.
mccrum
23
Australia
Okay will that need any "changes" for Australian sockets? Also can you send me the details?
- - - Updated - - -
And that tail doesnt exist?
raynewman
1,509
512
Brisbane, Australia
The 3 phase plug that comes with some UMCs don't fit Australian sockets, it's a European model. If you got one it was by mistake, as has been confirmed by Tesla.
Tesla Australia actually say (and I quote):
The only 3 phase adaptor is the European red plug. This can be supplied if you wanted, I believe cost is $130 + shipping.
I have never seen an outlet in AU that the red plug will actually fit, so up to you if you see a value in purchasing.
WA-T3sla
156
20
Perth, WA, Australia
Interesting. The pics I have seen seem to show the red plug is a moulded part of the connector that Plugs into the UMC. To adapt to Australia you would need a EU standard red socket and and Australian 5 pin 3 phase plug of either 20A or 32A with say 0.5m of cable between. I guesstimate costs for this would be $300-500
lennier
605
101
Whilst you could make an EU to AU 3 phase adaptor (probably) it would probably be illegal and the Tesla EU tail would still probably report the wrong pilot current and thus need to be overridden (if too high) or the resulting slower charging put up with (if too low).
raynewman
1,509
512
Brisbane, Australia
It's only illegal if you re-sell it.
WA-T3sla
156
20
What I was suggesting was you make a tail to adapt the EU red plug to either a 20A or 32A 3 phase plug. The tesla supplied eu plug will tell the car it can draw 11kW which is less than the capacity of either of those plugs. I doubt if this would really be illegal as it is in effect no different to any other international plug adaptor that you can buy at the airport etc.
Dborn
Confirmed
Aug 26, 2011
2,715
357
Sydney, Australia
Those adapters are meant to be certified though....
To make up your own tail you need to know the European wiring convention, Easy to find out, I guess, and theoretically get an electrician to wire up the Euo socket to the Aussie plug. That would then be legal and hopefully, safe.j
brewster
464
104
Warrnambool. Vic. Australia
Charging Options in Australia
Yep I have one, works well.
You either need to order it with a Type 2 Plug (which costs more), or you can use a J1772 adapter.
Do you know if there is a table somewhere which shows all the capable charging adapters that are available to Tesla Model S owners and their approximate cost?
It could be a handy resource for us noobs unfamiliar with the choices that are available and would help in deciding which adapters to purchase if any.
Something like this and I assume there are a number of errors in this and so I shouldn't show my ignorance, but if you could help correct the errors, fill in the blanks and add other relevant charging devices would be much appreciated.
DeviceAC/DCPhaseVoltsAmpskWCharge RateAvailabilityCost
SuperchargerDC
~480
Up to 450km/hrNowFree
HPWCAC1~24032- 407.6-9.6Up to 80km/hrNow~ $1000
Mobile 1 PhaseAC1~240102.4Up to 20km/hrNow~ $600
J1772AC1
Now
Mobile 3 PhaseAC3~480
CHAdeMODC
~ $1500
Thanks for you help. :redface:
dhuDz
138
0
Melbourne, Australia
DeviceAC/DCPhase InputVoltsAmpskWCharge RateAvailabilityCost
SuperchargerDC3~480200120Up to 450km/hrNowFree
J1772 Level 2AC1~2408019.2
Now
CHAdeMODC3~4806390
~ $1500
Gabz
232
3
Newcastle NSW
If you include all the 3rd party type 2 EVSE then you need a spreadsheet not a table google "ladestation typ2" and you'll see a vast amount "available" out of Europe which are Tesla compatible.
