AlanSubie4Life
Efficiency Obsessed Member
I doubt it. It's a completely different application with (probably) a totally redesigned subsystem of DCDC converter, etc. The Model 3 would destroy this battery, probably, since it is only 99Wh. (Anyone know the capacity of the Ohmmu for Model 3 (website still doesn't specify it clearly)? Their largest Ohmmu is $1000 but 2kWh of capacity (!!! - much larger than the 500-600Wh of the Model 3 OEM battery).)A couple of weeks ago, I set up an appointment with Tesla mobile service to proactively replace the factory lead acid 12 volt battery in my Model 3 with a lithium ion 12 volt battery. It was partly a question to find out if they could do that now. Service said it's not available, so I cancelled the appointment. However, now I see that that refreshed Model S comes with a lithium ion 12 volt battery, which is terrific!
Soooo.... Does anyone know if Tesla is at least planning to offer lithium ion 12 volt battery replacements instead of lead acid batteries?
I'd just get that Tesla replacement battery on order. I think pandemic exit issues are making lead-acid battery supply chains messed up. But you can have batteries for a good long time at $85 a battery.
