oh. Shame it didn't fix anything.I believe power off is the actual lingo.
I don't know if it will make any difference, but I always thought the method above was a Soft Boot. It helps with minor quirks and can be completed while driving. But pressing on the break pedal while then pressing the scroll wheels will cause a Hard Boot. The car must be parked for this method. Hope it helps. Good luck.Try a reboot, press and hold both steering wheel buttons until the screen goes black then release. Hopefully that does the trick and if not make an appointment via the app
This was long ago debunked as doing nothing different than the standard double thumbwheel resetBut pressing on the break pedal while then pressing the scroll wheels will cause a Hard Boot.
Maybe you just need to buy a new car?oh. Shame it didn't fix anything.
And that's literally how you reboot (reset/soft reboot/cycle/etc...) the car. The brake pedal was disproven a long time ago. You can and probably should do both the steering wheel reboot and the Power Off button if you're having issues. Those are both known as Soft Reboots. A Hard Reboot is removing the High Voltage connector under the back seat which is something most owners shouldn't mess with.This literally just restarts the touch screen. To do an actual reboot you need to go into the service menu and reboot the car. After 5 minutes, press the brake. Stay in the car and just wait while it goes through the reboot.
I believe @Mattopotamus was referring to the Power Cycling reboot which includes touching the brake pedal at the end to wake up the car (from page 52 of the manual) - not the debunked "press the brake pedal while double-scroll-wheel" methodAnd that's literally how you reboot (reset/soft reboot/cycle/etc...) the car. The brake pedal was disproven a long time ago.
So, there are three levels of "rebooting"Power Cycling the Vehicle
If your vehicle demonstrates unusual behavior or a nondescript alert is present, you can try power cycling the vehicle to potentially resolve the issue.
- Shift into Park.
- On the touchscreen, touch Controls > Safety & Security > Power Off.
- Wait for at least two minutes without interacting with the vehicle. Do not open the doors, touch the brake pedal, touch the touchscreen, etc.
- After two minutes have passed, press the brake pedal or open the door to wake the vehicle.
Just updated last night. No issues for me.Is anyone else having issues with this update? I just got the update notice on the app and haven't installed yet, because of this post.
I updated to 2021.4.12 last night and just now got back from a 25 mile trip. My auto high beams were also activated, but otherwise, everything was fine. Oh yeah, it was 32 degrees and I noticed that I had a bit more regenerative braking than usual at that temperature and there was no message about reduced regenerative braking. So I guess it's true that this update improves operation in cold weatherI just update from 2020.47.103 to 2021.4.12 and only had one small bug with Auto High beams being activated for some strange reason. Toggling the auto high beams off and back on fixed it..
- Restarting the Touchscreen (Page 51) - Hold down both scroll buttons on the steering wheel until the touchscreen turns black. Despite what the manual says, can be done while driving. This is commonly referred to as a soft reset.
- Power Cycling the Vehicle (Page 52) - See above. I guess this one could be called a "medium rest."
- Tesla Model 3 Hard Reset - as described on the Mountain Pass Performance web site. Not for everyone.
Glad I’m not alone. I’m dealing with this exact issue. Only difference is I’m in California, but not in Palo Alto. Cellular isn’t connecting either. Tried reset and powering down. Didn’t work.Car just updated to 2021.4.12 and all my settings are gone. Driver profiles have been deleted and settings have been reset.
The GPS also thinks I'm in California, not London. Some autopilot settings have been disabled too. And the car seems to have mysteriously developed the ability to use dual climate control.
Anybody else had similar experiences with this update? Or any other update?
