Purely speculation right now, but I think the 35K model 3 might have a new pack. But it is the same pack as the premium plus with 240 miles range. Similar to S75D and the S60D. It is just a software limited to 220 miles vs the 240 miles of the plus.
If this true, it might mean the 35K model 3 might be able to charge to 100% regularly without much worry about battery degradation.
Below are napkin math and base on some info about the midrange and such
Long Range Battery Capacity: 74KWh yielding 325 miles
Mid Range Battery Capacity: 62KWh yielding 264 miles
Standard Range Premium Plus: ~55KWh yield 240 miles
Standard Range: 55KWh yield 220 miles.
Ratio:
Long Range: 325/74 = 4.33 miles/KWh
Mid Range: 264/62 = 4.26 miles/KWh
Standard Range Plus: 4.36 miles/KWh
Standard Range: 4 miles/KWh - but probably software limited
If the Standard Range is indeed a software limited Standard Plus pack, that means about 9% missing capacity. I would think Tesla put it on the upper part meaning the max you can charge the Standard Range is 91%. Meaning you can probably charge the Standard to 100% all the time and it will be similar to a Standard Range Plus charged to 91% all the time.
What do you guys think?
Ratio:
