What do you mean?Not much difference but I’m still just a bit annoyed that they deprecated the RWD performance after the fact just to boost the appeal of the AWD model. The RWD could easily do 0-60 .3-.5 seconds faster than it does now.
just that 4-9 months ago, the RWD would consistantly clock 4.6-4.9 s 0-60 times, and now they will only do 5-5.1/2 0-60 times. The acceleration at initial launch has been reduced. It would seem that the acceleration in the mid-ranges is essentially the same though.What do you mean?
The pros and cons of OTA updates.just that 4-9 months ago, the RWD would consistantly clock 4.6-4.9 s 0-60 times, and now they will only do 5-5.1/2 0-60 times. The acceleration at initial launch has been reduced. It would seem that the acceleration in the mid-ranges is essentially the same though.
Its not clear if this was a cautionary move, reduce strain on motor, components, or if it was intentional in order to put a bit more daylight between at least the 0-60 times for the RWD vs. AWD model (which is spec'd at what 4.5s 0-60?)
before anyone says "where's your proof", just look at all the times recorded last fall 2017 and Q1/Q2 2018 either track results or youtube videos and reviews, and now they are all posting .5 seconds slower times as well for the/their RWD only models.
Awd vs Pawd - the Pawd has a better start; keep that in mind
^ Harder to get anything meaningful from that one since the non-P sorta flubbed the start.
j
Can you show me all these examples of the same people showing .5 seconds slower on the same car, same test equipment, and same location?
I haven't seen any- but could certainly have missed them.
Again, you aren't showing any facts. No one has shown a single car tested on a perfectly level surface in the same temperature conditions, same tires, same driver, etc and shown that the car is slower now than it was before.This is the fact not the argument. Tesla did slow down the RWD to place a gap between RWD, AWD and P-AWD. This could be mechanical changes or the OTA firmware restriction. But the fact is all Model3 RWD tested after 2018 Apr time frame is slower than the one tested in 2017.
This is the fact not the argument. Tesla did slow down the RWD to place a gap between RWD, AWD and P-AWD. .
