Model 3 annoying beeping sounds like 'morse code'
Do you hear a high pitched morse-code sounding beep in your Model 3?
  • Yes
    Votes: 35 63.6%
  • No
    Votes: 20 36.4%
  • Yes, only when the lights are in ON, PARKING or AUTO
    Votes: 4 7.3%
  • Total voters
    55
Hi,
I took delivery of my Model 3 (#4000-ish) last week and there are 2 things that really bother me about this car. One is the ridiculously loud blower fan, the other is I have an intermittent high pitch beeping, which sounds a lot like morse code, in the cabin. I can hear it driving at low speeds and of course when the car is sitting.
I noticed that the sound can be affected by the LED headlamps. If I sit in the car, and switch the headlamps from AUTO to OFF, the beeping stops for a bit, and then will eventually go back into its 'morse code' like pattern. If I switch the lights from OFF to PARKING, the intermittent beeping turns into a constant beeeeeeeeeeeep, which sounds a lot like tinnitus or ringing in the ears.
If I toggle between OFF and PARKING and OFF and PARKING, I can control the long beep. It sound a lot like a piezo buzzer. I'm guessing this has to do with the LED light drivers on the headlamps.
If I switch the lights into AUTO, or ON, the beep is still there, but it is masked a bit by the LED cooling fans on the lights. Putting the lights in PARKING keeps those fans off so you can isolate the beep.
I'm 33 years old, and have better than average hearing. My girlfriend can hear it, but my parents cannot.
Does anyone else have this issue?
If you're on an iPhone, does SpectrumView on the App Store pickup the noise? I'm guessing there are similar apps for Android or Windows/macOS/Linux if you don't have an iPhone.
One of the nice things about getting older is losing my hearing sensitivity for high pitches. I no longer go bonkers listening to power supplies in TVs. :)
ha! i will check out SpectrumView now, thanks for the suggestion.
here are the SpectrumView results, thanks to swaltner for the suggestion.
The "morse code beep" is at about 3625 Hz. One pic shows the spectrum peak as a snapshot in time. The other 2 show it with time as the x-axis (one is zoomed more than the other). You can see that it is intermittent.
Hi,
Yup. Mine does this as well, even my > 40 ears can pick it up. Seems to be coming from the rear/right area, and somewhat related to throttle position, but not regen -- if that makes any sense. Turn off lights/hvac/etc and do some steady-state uphill driving at ~ 30mph, and it'll present readily.
Other comment about it being like a coil-whine feels right -- it has that 'bad ground loop electrical whine' quality.
Reactions: davidc18 and pdxrob
how does one fix a "bad ground loop electrical whine"? where can we report this? i'm still awaiting a call back from the service center. any other channels to bring this to Tesla's attention?
I have an appointment (well, had, they canceled it overnight "per my request" that I never made) Wednesday at my local SC for a "Contact Tesla Service" alarm that came up after the recent firmware update -- was planning on bringing it up then.
I wonder if it's the audio amp picking up something that is badly earthed?
My MS makes a digital "chirping" noise which is very similar to an analog modem (could be described as "morse") when I press on the brake. It is very quiet, and I can only hear it at low speeds in my parking garage.
