Your search - ≡ - did not match any documents.
My advice is if ≡ means a great deal to anyone that they put it in their signature or as their avatar.
You just restated the very bias I was speaking of... What matters is the results, not the theory. When the EPA created the algorithm for determining 'efficiency' for EVs it built in weight as a factor in an unfair manner. It was based upon the presumption that all EVs would be teeny, tiny, dinky, wimpy, impractical, low range, econo-boxes -- instead of being 'REAL cars'. The same sort of bias was used for determining 'Green Cars' for LEEDS certification. As a result, the Tesla Model S isn't listed among them, but multiple gas burners are... Too often such things are determined by people with an extremely narrow focus, instead of looking at all the possibilities. No one expected an automobile manufacturer to ever put a relatively massive battery pack in a car, so they didn't allow for the eventuality in their calculations. That is an inefficient process of evaluation, not an inefficient means of making a vehicle.While your reasoning is right on for the rest of your post, this part isn't quite right, the reason that the longer range EVs are rated with a worse MPGe rating is not because the EPA is biased towards low performance vehicles, it's because the extra range comes at the cost of a heavier battery pack, which makes the vehicle less efficient simply because it has to lug around the extra weight.
The weight of the car should not matter. What matters is what it does. If someone manages to make an 8,000 lbs two-seater that gets 250 miles per gallon, has a twenty-five gallon fuel tank, and can be driven over 6,000 miles without refueling it should not be given a lower efficiency rating than a car that weighs 3,000 lbs, seats four, gets 40 miles per gallon, and has a ten gallon tank. That would be ridiculous.What on Earth are you talking about?
The EPA is giving cars that have a maximum of 76, 82, 84 miles of electric range an MPGe rating of over 100, but rated the Model S 85 -- which they confirmed has a range of well over 200 miles -- at 89! SEE THE RESULTS YOURSELF. Neither of the cars that have that MPGe rating even store enough energy in their batteries to match the 33.7 kWh the EPA says is the basis of the rating. That is what I'm talking about!
MPGe Rating has nothing to do with range or with kWh of battery capacity. It has to do with efficiency at turning power into miles traveled or Watt/hours per mile. A Leaf has a higher MPGe rating because it gets more miles per kWh than the Model S.
By your reasoning adding a larger fuel tank to a car should get it a higher EPA MPG rating since it has more range. That makes no sense whatsoever.
The Model S is not particularly efficient.
What did they set regen on.
Dude. Did you actually look at the link I posted? The one that goes directly to the EPA's website, FuelEconomy-dot-gov...? The one that shows "EPA Fuel Economy" as the formula "1 gallon of gasoline=33.7 kWh"...? The one that specifically shows the range rating of multiple vehicles, and their MPGe based upon calculations for "kWh / 100 mi"...? This is EXACTLY what it stands for... it is not MY reasoning behind these calculations, but the EPAs... And they are BIASED in FAVOR of smaller electric vehicles that can NEVER achieve the range that their MPGe intimates.MPGe Rating has nothing to do with range or with kWh of battery capacity.
Agreed. The Leaf is much more efficient than the Model S - real world... The Model S is not particularly efficient.
This confuses a lot of people. The MPGe figures measures the kWh that comes from the outlet and has nothing to do with the capacity of the battery in kWh (except indirectly). This means it includes charging losses (which varies depending on the car). That's why none of the MPGe figures match up with the range and capacity figures (usable or otherwise).Dude. Did you actually look at the link I posted? The one that goes directly to the EPA's website, FuelEconomy-dot-gov...? The one that shows "EPA Fuel Economy" as the formula "1 gallon of gasoline=33.7 kWh"...? The one that specifically shows the range rating of multiple vehicles, and their MPGe based upon calculations for "kWh / 100 mi"...? This is EXACTLY what it stands for... it is not MY reasoning behind these calculations, but the EPAs... And they are BIASED in FAVOR of smaller electric vehicles that can NEVER achieve the range that their MPGe intimates.
My cabin is 300 km away over two mountain passes. My Leaf can't take me there, or if it could, it would be an enormous task with a lot of wasted effort. My Model S can take me there with range to spare. So to me, the Model S is far more "efficient" than the Leaf:
ef·fi·cient: (especially of a system or machine) achieving maximum productivity with minimum wasted effort or expense.
Originally Model S was meant to be $50k, ended up being $75k-$100k
