voip-ninja
Give me some sugar baby
I think this probably explains why Tesla sandbagged the range numbers on the Model 3 LR RWD.... They can claim same range across the whole Model 3 LR family by using the 8% lower value for the AWD.
This doesn't state the AWD will get lower range in a mixed use yet. We need more information before we can draw that conclusion.I think this probably explains why Tesla sandbagged the range numbers on the Model 3 LR RWD.... They can claim same range across the whole Model 3 LR family by using the 8% lower value for the AWD.
You're harshing the AWD buzz, dude!May we also stop repeating this marketspeak of 'torque sleep'? It is just a boring freewheeling of a deadweight, nothing fancy.
Dude, doesn't matter, AWD is still faster It's 100% of the reason why I'm getting it instead of RWD.You're harshing the AWD buzz, dude!
You were however spot on with "it's best to never have the mass that needs spinning up and things that'll have non-zero friction".I was not aware of this fact and stand corrected. Thank you.
You're so vain, you probably think this post is about you.I'm getting it for the gaudy badge on the trunk lid.
X_x
Wait.... they haven’t gotten EPA certification yet?...We still need the EPA certification...
Can't this current be used to recharge the battery?Torque sleep still involves trying to control the current loop to 0. You can’t just spin a motor as deadweight without generating a back EMF. That’s especially true for permanent magnet motors, where they will passively generate if spun (it’s actually a serious electrical shock hazard to spin the shaft while the leads aren’t hooked up). In AC induction motors it also turns out to be true because the ferrous metals tend to be weakl magnetized over time. And that’s enough to generate just a little bit when spun.
Back when I was a motor controller engineer we actually used the latter effect to do sensorless startup on induction motors. It was a huge shock (no pun intended) that it worked — but we actually shipped it as a reference platform.
Do you have any insight into how 'big' this magnetization effect is and how it effects normal motor operation through its life, say after 150k miles, 10 years of operation?
"I'm sorry. I know I said I'd give you a ride, but for optimum range, I have to choose between bringing you or my front motor."...it just becomes a LR Model 3 with ~150-200lbs more deadweight up front...
"....so unless you're willing and able to get out and help by giving a push start to keep my 0-60 under 5sec, you're going to need to call a taxi.""I'm sorry. I know I said I'd give you a ride, but for optimum range, I have to choose between bringing you or my front motor."
I doubt it's using the front motor at all in this test. Why would you use the front motor when the rear is more efficient? The difference is probably mostly the friction from the axles (CV joints), gearbox, and front motor. The weight is probably a much smaller contributor since you get most of that energy back with regen. The highway efficiency should be much closer since the most of the loss at high speed is from wind resistance and weight hardly matters at all.150-200 lbs is equivalent to having another passenger in the car.
Is that effect measurable? Of course. But I do not expect that to have a real world impact. For example, I don't plan trips any differently depending on the number of passengers in my Tesla.
The highway efficiency will be slightly lower than RWD but not by much. The reason this test showed an 8% hit is because a greater share of the horsepower was derived from the less efficient front motor.
