Model 3 body repair guide released; reveals what metals are used where
Discussion in 'Model 3' started by KarenRei, Aug 22, 2017.
Tags:
  1. KarenRei
    KarenRei KarenRei KarenRei KarenRei KarenRei KarenRei
    Iceland
    Link. Four categories are used - alumium (mainly the front crumple zone), low-strength steel (mounted to the safety cell, also forms the fenders), high strength steel (part of the front crumple zone, also the battery pack) and ultra-high strength steel (passenger safety cell and its connection to the rest of the body). Body panels are not shown, but are believed to be alumium. Everything but the ultra-high-strength steel is repairable; the latter may only have things welded to it. You also need to use boron or tungsten carbide drill bits to drill through it.
    • Informative x 8
    • Helpful x 2
  2. kwest2
    kwest2 Member
    Boston, MA
    Neat!
    ....is this good or bad?
    lol
  3. KarenRei
    Iceland
    #3 KarenRei, Aug 22, 2017
    Shows that it's the latest tech. Given the crash results, and the low mass, there's no surprise that they're using UHSS, but it's nice to see that they're not skimping on materials. UHSS is hard to work with because it tends to just spring back after you stamp it, so there's a number of new technologies to try to make it more suitable to mass production. It's tough on manufacturers, but good for owners ;)
    • Informative x 4
  4. e-FTW
    e-FTW New electron smell
    San Francisco, CA
    Does this mean that when I move back to winter land, with a shiny Model 3, I'll have to do rust treatments?
    Or are people doing that with S/X for whatever steel is in there...
  5. Dynastar
    Dynastar Member
    Billings, MT
    Share the document? I can't get it to download.
  6. anticitizen13.7
    anticitizen13.7 Enemy of the Status Quo
    United States
    It depends on how well Tesla has sealed off the steel from outside conditions.
    Many Japanese and Korean cars from the 1980's and 1990's developed rust in northern US states because their undersides weren't shielded well and/or had areas that trapped salty slush. By the 2000's use of zinc coatings and other sealants made newer models far less prone to corrosion. Even so, some cars like the Mazda 3 still suffered rust issues.
    We probably won't have any idea of how Model 3 wil fare until someone puts one on a lift and takes photos. And it will be years, possibly a decade, before it's known how well Tesla's steel unibody construction holds up to salty winters.
  7. KarenRei
    Iceland
    They took it down. Here's a jpeg of it: [​IMG]
    • Informative x 10
    • Helpful x 3
  8. e-FTW
    San Francisco, CA
    That is fair. Totally agree on the Mazda 3 as a main offender.
    I shall not base my expectations for the Model 3 on the Mazda!
  9. KarenRei
    Iceland
    Ah, found it in my cache. Attaching.
  10. KarenRei
    Iceland
    As for rust:
    * The panels (not pictured) are alumium. They will not rust. If Tesla has not properly isolated from the steel they could undergo galvanic corrosion. One hopes that their QC and design are sufficient to prevent that.
    * It's not clear whether there is an inner liner or panel (not pictured) on the fender. It looks to me like there probably is, given some of the holes in the mild steel. This would be good, as this is a higher corrosion area due to tire splash.
    * The high strength steel underside, if it's done like the MS, will be exposed. If so, it's either going to have to be hot-dip galvanized, made of a corrosion-resistant steel, or some other similar protection mechanism. Contrarily it could have an underpanel (hopefully not plastic, I've had problems with them being repeatedly sheared off by snow and ice on my Insight, to the point that I just gave up on replacing them) or rubberized coating. Or a combination.
    * Mild steel is not going to be inherently corrosion resistant. It's used where you need a cheap, ductile steel. As for the high strength or ultra-high strength, it depends on the alloy. Either way, a company making a $35k base MSRP car is going to take corrosion protection seriously, especially given the well-known failures of the past.
    Don't pity the reduction in alumium too much. Alumium is great in some respects, but a pain in others. One of the most annoying is metal fatigue. Steel takes repeated flexure like a champ; alumium becomes brittle and ultimately cracks. It's is also harder to weld. And of course, as mentioned before, if you have alumium in direct contact with steel, the steel will corrode the alumium - potentially very quickly.
  11. chronopc
    chronopc Member
    The colors totally remind me of Legos.
  12. Dynastar
    Dynastar Member
    Billings, MT
    Thanks, very interesting. I wonder why the trunk area is aluminum when most of the rest of the frame is not. Weight distribution?
  13. KarenRei
    Iceland
    My thoughts are, you want the trunk crushing in a bad accident.
  14. SageBrush
    SageBrush 2018: Drain the Sewer
    Colorado
    I've been wondering how Tesla was able to make a car so much lighter than the Model S.
    Do these materials answer the question ?
  15. 22522
    22522 Active Member
    Texas
    Lots of good choices there.
    On the Civic, Honda actually quenches different parts of the same piece of steel at different speeds to get characteristics.
  16. e-FTW
    San Francisco, CA
    “Quenches”? Curious as to what that is.
  17. insaneoctane
    insaneoctane Active Member
    Southern California
    Heat treatment due to rapid cooling.
  18. Phrixotrichus
    Phrixotrichus Member
    Germany
    The material mix is actually pretty standard. Some premium models use more aluminium, but all in all nothing spectacular here.
    Weight is also not such a big problem for EVs (if you`re not a 0-60 fanatic :) ) since their recuperation abilities keep the efficiency relatively high nonetheless.....
  19. KarenRei
    Iceland
    Model S is also built light, structure-wise. It's however a larger car with a more powerful drivetrain, so it makes sense that its curb weight would come in at ~15% higher for the same sized battery pack.
    These materials are more to answer the question of, "how did they make M3 light in this price range?" :)
  20. chronopc
    chronopc Member
    sounds like a blacksmith term
