Model 3 charging adaptors question
asherwood
105
40
UK
Hi
I’m aware that the model 3 supports type 2 adaptors, however looking at a lot of rapid chargers they have different types e.g. ccs.
Is there any support in the model 3 for these other types in the UK or are we limited to type 2?
thanks
Scott
NorfolkMustard
2,140
2,073
M3P w/FSD
CCS is a combined standard, at the top of the connector is a Type 2 and at the bottom are the two phat pins for DC
Your home AC charger will just use the top Type2 part of it.
At DC fast chargers, including Tesla Superchargers, you’ll want to use the CCS cables
It’s as if someone thought this through just a little ;)
Combined Charging System - Wikipedia
at Tesla Superchargers you can only use the CCS one, the (modified) Type2 cable only fits model S/X - see the little triangle notch on the centre pin below
BK11SBY
34
17
Northamptonshire, UK
Type 2 is standard on S3X
CCS is Type 2 with 2 Large DC pins added underneath, standard on 3 (supported with adapter on SX)
Chademo only supported with bulky adapter S3X
Chademo is on the way out as I understand, so I wouldn't worry, as a 3 owner you are well covered. with Type2/CCS
