Two of the three glossy parts are easy to remove. You just pry off the soft touch side panels (about 6-7 clips, and it pulls right off), them remove the aluminum side rails that are attached with half a dozen sxrews. Removing the phone door is harder, the hinge has a screw on each side, then there is a third screw on the left side that you have to hold the door in a certain position to reach. Be careful not to drop the screws into the console! The cup holder also pops off, but it took a scary amount of force. That tiny area has about seven clips holding it in place, plus you have to be careful not to rip the wiring harness for the key reader. I think removing the storage door (the middle of the three pieces) would require disassembling most of the center console, which I wasn't able to do.
It looks amazing, and was worth the effort.
