Model 3 Cooling System System
Discussion in 'Model 3' started by electracity, Jul 26, 2018.
  1. electracity
    electracity Banned
    For those interested in the details:
    • Informative x 2
  2. chronopc
    chronopc Active Member
    What are your thoughts on keeping the car plugged in all the time as the manual suggests. Do you know if the battery cooling system needs the car to be constantly plugged in?
  3. TurnFast
    TurnFast Member
    Redmond
    Huh, I wonder why they didn’t use the heater for the cabin to heat the batteries as well (like how the cabin and batteries share the same compressor for cooling).
  4. ewoodrick
    ewoodrick Well-Known Member
    Buford, GA
    While you have one where you can see a lot of it, is there any way to run cables from the frunk into the passenger compartment? For example, to install Amateur Radios or other equipment that need access to 12V power and other things, such as an antenna?
