Model 3 crazy vampire drain
URFIR3D
129
78
Arlington, VA
Another data point... I've been keeping an eye on my vampire drain and it appears to be close to 1 mile an hour when left unplugged. Car has been parked outside at home (mid 80s to low 90s temps during the day in the last several days) with the cabin overheat prevention enabled, as well as in a parking garage at work. I am NOT using my smartphone as key; instead I've been relying upon the keycard for access. Tesla app on my phone has been set to unmonitored power. Random checks during the day using the app indicates that the car is "waking up" to provide current data. Car has had version 2018.24.1 since day one.
Do not open the app, that will drain your battery, instead use the widget to check the status without opening the app.
Also, I deleted the app from my phone completely and it didn’t make a difference.
TexasEV
7,640
8,464
Austin, TX
The Tesla app is not the problem (unless you use it to check the car obsessively, then you’re the problem, not the app). The problem is third party crap that causes vampire drain even if you think you’re not checking the car.
Reactions: Randy Spencer
URFIR3D
129
78
Arlington, VA
Yes I am aware, I was just clarifying to someone else. They specifically mentioned that they frequently check the app. So if you open the app every 1-1.5 hours, you will keep your car awake all day. But the app on its own is just fine, but if you want to keep checking on the car, then at least use the widget and don’t wake the car.
I don’t use any third party apps, and rarely check my Tesla app. So I know my issue is not app related. I’ve got something wrong with either the hardware in my car, or something with the battery management module.
Thaiverson
25
12
Huntington Beach
Just picked up my M3 on 7/7 and I am also noticing vampire drain. First night, I charged it to 276 miles (my default set-point). 4hrs after it completed charging, I checked the Tesla app and it was reading 165 miles.... -11 miles in 4 hrs!! Called the Tesla number but the service center was closed on Sundays so ended up talking to some representative. The rep said he would call me back on Monday when the SC was open, but never received a call and I’ve been too busy at work to call them back. Latest data point (last night til this morning) the car went from 200 to 195 miles over 10 hrs.... so definitely erratic, but even at this “better” rate, that’s still -12 miles in a 24 hr period. Seems excessive no?
URFIR3D
129
78
Arlington, VA
Are you using any third party apps that use the API? Like TeslaFi or Tezlab?
Is the car indoors or outside? What’s the ambient temperature?
Msjulie
2,425
1,733
Monterey Bay Area
FWIW I've noticed that vampire drain seems much reduced with the current firmware but there is drain when the car is parked outside in the hot sun; thinking it's keeping the battery temp stable?
Firmware 2018.21.9
MP3Mike
14,978
31,851
Oregon
I don't think i have cabin overheat or at least nothing in the phone app suggests it - i can manually turn on climate controls but that's been there a while
Cabin overheat protection is only controlled in the car itself, and it defaults to on if I recall correctly.
Msjulie
2,425
1,733
Monterey Bay Area
Shouldn't I be able to turn it off, especially since I may leave the car for a protracted amount of time and charge is more important that a hot cabin when I return...
MP3Mike
14,978
31,851
Oregon
You can only turn it on/off from the screen in the car. (It is intended as a set it and forget it type of thing.)
Msjulie
2,425
1,733
Monterey Bay Area
My car doesn't have it - and I know because I just ran out and went through every screen I could find.. since I have seen reduced drain I'm thinking it's not related to this feature which I don't seem to have yet/can't control
Electroman
6,114
6,167
TX
I lost 30 miles over 11 days parked in my garage. That is about 3 miles a day. Not excessive, but they should get this down to 2 or 1 mile a day.
MP3Mike
14,978
31,851
Oregon
What version are you on? (I think there was a version that had it but it was hidden and always on.)
RayK
1,835
1,786
San Jose, CA
I'm losing about a mile an hour. This is with interior temps reaching only 80F and estimating outside temps in the 70s. Car is sitting in a parking garage at work. I am checking remotely about every hour and the app seems to be saying that the car is waking up each time I do. I recently signed up.to be a beta tester for teslogs.com. Drain hasn't increased significantly since then. I wish I was seeing 3 miles per day!
Also should say that I'm seeing about the same loss overnight at home where my car is sitting outside in my driveway.
Currently on 2018.24.1.
URFIR3D
129
78
Arlington, VA
If you are using your Tesla credentials anywhere or using the API anywhere, changed your Tesla password (which will revoke your API token), and see how your drain is at that’s point. There are a ton of people that lose 14-16 miles per day if they use any third party apps/services that pull data from your car or use your credentials, then lose only 2-3 miles when they disable those.
Let us know how yours does...
I’m losing 20 miles per day, even though I’m not using any services, which def is abnormal. Curious if you are in the same boat, or if your loss is due to other apps/services.
RayK
1,835
1,786
San Jose, CA
I'm fairly sure that I'm only exposed at Tesla and teslogs.com. I use the keycard and NOT my smartphone to operate the car so proximity of my phone to the car is not an issue. The drain has been higher than the average 1MPH I quoted above when I know that the cabin overheat has kicked in. I'm keeping an even closer track on the drain since signing up with teslogs two days ago. At the moment the car is home charging so I won't have any data for a couple of more days.
URFIR3D
129
78
Arlington, VA
I guess I’m saying if you want a real idea of your drain, or if you are having issues, change your Tesla password to disable Teslogs, and see if that changes anything.
