Model 3 crazy vampire drain
TexasEV
7,640
8,464
Austin, TX
No kidding, I'm at 1 mile per hour of loss. Even more bothersome, I got the car to sleep after changing Teslafi settings, and it still drained a mile in about an hour and a half...
So maybe you didn’t really get the car to sleep after changing the TeslaFi settings? Before assuming the car has excess vampire drain you need to delete TeslaFi or any other third party app communicating with the car, and change your Tesla password. Then see what happens over the next 24 hours.
Goatdan
83
122
Wisconsin
Since I really, really like the Teslafi data, I've left it for now to see how it changes with the new settings (so far, it's considerably better, although still about 10 miles per day). I might wait to see what V9 brings in the energy data to decide what to do.
sbtz
298
96
southern california
What settings are you using in TeslaFi?
BrandonLive
P3D+, Blue on white
Sep 24, 2018
200
201
Seattle
How did you determine that last part? Just watching it go down one mile in the indicator after 1.5 hours doesn’t really help, since you don’t know how close it was to the boundary when you started. If you saw a second mile disappear after another 1.5 hours, that would be a stronger indication of a problem.
Reactions: SageBrush
SageBrush
REJECT Fascism
May 7, 2015
12,084
14,993
New Mexico
I'm cautiously optimistic that my vampire drain is 1-2 miles a day. I'll wait for a 2-3 day break from use before declaring a definite improvement over the 2 - 4 miles range loss I am used to seeing.
Success will be at 10 watts average ( one EPA mile a day.)
BrandonLive
P3D+, Blue on white
Sep 24, 2018
200
201
Seattle
I seem to get 1-2 (3 tops) of vampire drain on my 3. Obviously less would be better, but I can live with that.
When I connect via the app it often waits and says “waking up”. I assume that every time I do this (and it’s not plugged in) it causes a bit more drain.
I suspect they’re mostly using PC hardware there, versus mobile (e.g. ARM with very low power modes that still enable connectivity). Probably similar to an Xbox One in that it has a “standby” mode that acts more like a phone (or what Windows calls Connected Standby), but actually still draws non-trivial power.
9erDog
249
316
Cypress, CA
Just back from a trip. Left Saturday morning 9/29 early but had not checked on the car since Friday evening. Returned last night 10/6 and checked on car. Loss was a total of 13 miles over 8 days. I am fine with this loss rate.
LR RWD EAP 36.2 not plugged in.
dfjkl
39
28
Chandler, AZ
My vampire drain seems to be getting worse over time. Only seemed to be a 2 - 3 or so in the beginning, but I'm approaching up to 10 miles now on some days and seem to be averaging around 5/day now. This seems excessive.....
URFIR3D
129
78
Arlington, VA
Is your car out in the cold? Cause that will do it. My car will lose 2-3 miles per day if kept in a 70 degree garage. 8 miles if it's 40-50 and raining, I'm sure it will be about 10 when it's 30 degrees.
That is all considered normal.
sbtz
298
96
southern california
My vampire drain was related to TeslaFi. I had been using it for 2yrs with my Model S with no issues. Changed it over to my 3, same settings - massive vampire drain. It's been fine since I stopped using it - I might lose 2-3mi/day these days. YMMV.
privater
2016 Model S and 2017 Model 3 owner
Jun 22, 2016
254
735
Try this:
Reactions: sbtz
Randy Spencer
3,121
3,022
Alameda, CA
I think for me the WORST thing, the thing that made me worry about my loss of range, was TezLab. Their display is REALLY difficult to understand. Why am I shown as losing 26% of my electricity on average? Why does it show me losing 17 miles of range in a day? What is really going on?
Why is it all over the map?
When I was trying to figure it out I had to remove everything from my car so I started using the Tesla app to snapshot the charge level twice a day. That made it obvious that I wasn't loosing all that power while the car just sat, it was going to turning on the heat or the AC before I get into the car. To sitting in the car listening to the radio and waiting for the wife to come out of the store. To sitting in the driveway and adjusting the radio or browser presets.
That's not phantom, perhaps instead of starting to watch for drain when we put the car in park, it should wait until the car is locked and the environmental systems are off. Add a category called Idle that tallies the loss when we are in the car and not driving.
I have since put almost all the apps I had back on the phone and not having an issue, but just to be sure I will wake the car at 8 am and 8 pm and take a snapshot of the range remaining. As long as it's 1-2 miles I am happy, getting the expected loss.
-Randy
TT97
2,168
2,894
Los Angeles
TeslaFi recently started doing it that way:
Perry
1,050
734
San Jose, CA
That's pretty low. I get 15 miles per day phantom drain loss.
TT97
2,168
2,894
Los Angeles
15 miles is crazy. I lose between 3-8 miles per day depending on how many drives I do throughout the day. When traveling, definitely under 3 miles lost per day.
Do you precondition or have overheat protection on?
KootsChewt
118
108
Nelson, BC
I feel like I am losing an excessive amount of range with this car (I'm coming from a Leaf) - I've read through a good chunk of this thread and the manual, and expected I would see about 0.75 kWh per day (~1%). However, even before setting up TeslaFi, I was seeing more like >3%. I'm seeing about the same with TF, ranging from 2-4%. One outlier day I saw 4.5 kWh (~6%!) in 15 hours of straight "sleeping" by the car - 32 km (20 miles) of range!!
McFlurri
1,441
1,533
Kitchener, Ontario
I also lose an insane amount of range over night.
sumpty
7
12
Capitola
I was losing 23 miles of charge a day ( basically 1 mile an hour). It was 45° at night and around 59° in the day. I called Tesla and they said that can be completely normal in “cold weather”, “the battery likes to be kept at 60 degrees” they said. But then they told me to try a firmware update and I did. Now the car is losing like 3-4 miles of charge in like 17 hours in the same temps—much better!
McFlurri
1,441
1,533
Kitchener, Ontario
Which firmware update would that be?
Im losing the range like crazy.
