Model 3: Cuphead Won’t Load
Cuse
5
0
Mass
Hey all, I finally got a DualShock our to my car. The car recognizes it because it allows me to hit “Play.” The game screen goes black with a spinny circle thing indicating its trying to load, but it just spins endlessly.
I tried resetting the car but no luck.
Anyone else had this issue? Know of a way to resolve it?
Perscitus
725
439
New York
Controller usb handshake issues.
While its doing that unplug the controller/s and magically the app will exit the loop and joyfully inforn you to plug in a supported controller. Plug back in to resume circle of death.
Fix? Pickup a different controller or overhaul your usb hub or splitter setup or both.
Cuse
5
0
Mass
Thanks! Happened as you said. Unplug and it says connect controller. Plug it back and resumes spinning.
Im using a DualShock4 (2nd gen) plugged directly into the front port. Everything I read said it should be compatible. It’s weird because when I plugged in a non supported controller (dual shock 1st gen) I didn’t get the option to press the play button at all. So it seems like it registers this one as connected but still isn’t compatible.
Do I need a new controller?
