Did a little bit of research on silicone sprays. This is supposed to be the *sugar*:
https://www.amazon.ca/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG
Just ordered some myself.
Thanks, ordered as well.
None of these issues on the Model 3 is exclusive to it, even among other manufacturers. The windows work as all vehicles with frameless windows, the mirrors work the same as all active mirrors, and the handles are similar to the GTR.
This is just more FUD, no different from any other FUD. At least you can mitigate most of these issues with an App...something that can't be said for all the other vehicles with the same EXACT issues.
I see absolutely no advantage of the frameless windows to offset these disadvantages -- do they have any advantage? If the car were a two-door coupe, I suppose it would make the car look more like a convertible. But on a 4-door sedan, they seem to serve no purpose whatever.
Subaru’s rationale for doing it was they could put more material in the b-pillars and the roof (instead of the doors)
Are there many cars with frameless windows? I have never had one before my S, and in my opinion it is the single worst design feature of the car. It takes a fair amount of extra effort and precautions to be sure you can open and close the doggone doors in cold weather, just because of the frameless windows, so I think they are totally impractical for a car used in winter (especially if parked outside as mine is). My other concern about the frameless windows is the constant extra wear and tear on the window lift mechanisms -- they must work each and every time a door is opened or closed, adding considerable extra cycles to the mechanism.
Otherwise, the Model S is pretty good in the cold, especially with the Sub-Zero package. But I agree that it is best to shut off the automatic mirror folding.
Same. Put the order in last night. I have had cars with frameless windows before and do not recall ever having a real problem (other than in some severe ice storms which are not the norm) but all these threads and postings have me really nervous about the 3 in the deep winter. (I was “cautious” enough about it re battery issues - let’s hope this does not become an everyday common occurrence.)
Many premium vehicles come with frameless windows, and as far as I'm aware it's almost exclusively aesthetic. As they're more complex you'll see issues with them pop up in vehicles from all manufacturers.
I have yet to have any issues with my windows, and our winters aren't exactly a walk in the park.
You have been lucky. Stay tuned -- with the right combination of temperature and moisture, eventually one or more of your windows will freeze in place. The trick is to preheat enough to melt any ice, or at least enough to allow you to easily scrape off the ice. The suggestion above to use silicone spray on the gaskets is probably a good one, too.
Someone else mentioned a possible software improvement that would automatically direct the vent output heat towards the windows during remote warm-up to attempt to defrost the window seals.
Well, due to the nature of our winters the Model X has either been in our garage, or a parking garage, and I always preheat the vehicle. I think I'll look into the silicone spray, too, as I see no reason not to take precautions.
Does the Model S have scheduled pre-heating? The other problem I'm having is the charge port (not the cover) failing to unlock and the solution for that is 2 hours with the car on HI and the rear seats down. Scheduled pre-heat would help?
Maybe someone here who can replicate the frozen lock and window issue can try altering the vents and see if preheat then fixes it. If it does then Tesla can roll it out as a software fix
The S/X have "Smart Preconditioning," but not a scheduled pre-heat, per se.
My car was fine today after I used the silicon on the seals, we'll have to see how well this holds up after a couple of weeks.
