Why is the rear plate off centre?
It's not, the camera is off center to make room for the boot lid button and light.Why is the rear plate off centre?
I'd personally got for a plate with GB on it so I don't need that sticker in France. The new "green" plates dont have it.I too went for the shorter plate. I removed the long plinth and stuck the plate straight onto the bumper (clean it thoroughly). In fact, I’ve used 3M heavy duty Velcro so that I can reuse my old long plates with the GB logo for travelling on the continent (wouldn’t want to use the single use GB stickers)
Haha, I had this with my stuck on plate. Because of the curvature of the car’s bum, the plate looks crooked from almost every angle!It's not, the camera is off center to make room for the boot lid button and light.
Yeah, had a nightmare on my last car... Went with stick on physical plate after trying the label due to the dips.Haha, I had this with my stuck on plate. Because of the curvature of the car’s bum, the plate looks crooked from almost every angle!
Oh I know, I meant the plates the car came with.UkRegPlates now does them, and they're retroreflective: Number Plate Builder for Replacement Number Plates - UK Registrations
Hi,I too went for the shorter plate. I removed the long plinth and stuck the plate straight onto the bumper (clean it thoroughly). In fact, I’ve used 3M heavy duty Velcro so that I can reuse my old long plates with the GB logo for travelling on the continent (wouldn’t want to use the single use GB stickers)
You can just cut your standard one down which is what I did for my rear. To stay legal, you need 11 mm around the outer edge of the numbers and letters.Hi,
I would like to go with a shorter plate, Ona shorter plinth, rather than a sticker. Do you know if that is possible on a model 3, and where I might get them?
He wants a short plate though. It’s fine for a normal sized plate on the front (the rear isn’t) but not for the chopped short plates.The black mounting plate at the front is shorter than the plate any way, and is about the same size as a narrow plate. Just use 3M abd mount it to that. I did it with a full sized plate and it's fine.
Before you start buying stuff, go out and take the Tesla plate holder off (2 crosshead screws) and you'll see.
I believe if part of what you chop off is the BS number which is on the bottom right corner, the plate won't be legal. (I don't make the rules).You can just cut your standard one down which is what I did for my rear. To stay legal, you need 11 mm around the outer edge of the numbers and letters.
Yes you're right, I was misremembering how long the mounting plate was. Not that much shorter either side of the plate.He wants a short plate though. It’s fine for a normal sized plate on the front (the rear isn’t) but not for the chopped short plates.
Oh blimey. I never spotted that. Oh well, I’ll just take my chances with it now.I believe if part of what you chop off is the BS number which is on the bottom right corner, the plate won't be legal. (I don't make the rules).
