Watts_Up
Sharing my setup for carrying a full diameter spare tire with me (T135-80-R18 104H).
The holes on the sides of the upper structural beam of the trunk are used to hook straps
to hold the tire up so that I still have access to most of the trunk and the lower compartment.
Did you tried also to put the spare horizontally under the speaker shelf?
Doing so, you can still put some long items when folding the back seat, but the cleareance is only 12" instead of 18".
Note: It's a pitty that there is a beam in the middle of the trunk, otherwise it would have been easier to put a tire flat on the bottom of the trunk.
Note: Note: I plan to remove the inside liner and lower the lower trunk well cover,
and put some insulation directly on the metal, so I could get an extra 3" height of storage.
(see the location used by the un-inflated spare tire on the picture below)
I winder if the Model Y would have a better design, or if the third row will take most of the available space?
Note: Since the Model Y has a hatch, the only possibility to carry a spare will be to put it flat on the floor,
or to put the tire vertically on one side of the trunk.
