model 3 height off the ground?
Discussion in 'Model 3' started by tsla007, Jun 23, 2016.
Tags:
  1. tsla007
    tsla007 Member
    CT
    Anyone know the height off the ground of model 3?
    We have a steep hill to get up and want to make sure we can clear it without killing the front bumper. It goes from 0 to 12 degrees immediately. The town admits it's a bad taper or no taper but if they taper it it would make the hill steeper and harder to get up in the snow.
    Might have to get the upgraded suspension.
    Thanks in advance.
  2. Tiberius
    Tiberius Member
    SoCal
    Even if someone went through the trouble of measuring the exact height from the reveal pics, there is a good possibility that it will change since those were only prototypes. Way too early to be asking.
  3. YBT
    YBT Member
    Australia
    These kinds ot things aren't known yet and won't be for a while. Best way to find out in the mean time is to discover the articulation of the Model S Air Suspension - the system in the M3 will likely perform within similar spec as its bigger brother.
  4. strykeroz
    strykeroz Member
    Brisbane, Australia
    This is of concern to me also. Our driveway is very steep, and low or long vehicles can have issues getting off the street, and at the crest near the garage doors. We had a small sedan that scraped the tail pipe at the top, but could get over the footpath at the right angle. I'm hopeful I'm far enough down the reservation queue that we can get a real one to try out before I press submit on the order. Or that air suspension is an option as @YBT points out.
  5. T34ME
    T34ME Active Member
    Inland Empire
    Interesting thread. I have been contemplating this question also for my Model 3. Air suspension for the Model S is $2500, which I think is reasonable....depending. What is the height difference in a Model S from aired up to aired out? How well does air suspension work? Any Model S owners out there with air suspension who might be able to provide some wisdom?
  6. melindav
    melindav ☰ reserved
    Vancouver, WA
    dropping a photo into CAD and adding a 12° slope, it looks like there should be plenty of clearance (based on the ride height of the photo car)
    • Informative x 3
  7. KeRaSh
    KeRaSh Member
    Germany
    I saw this post back in june and looked at my parking ramp at home and freaked. The technical sheet said it's a 22 degrees slope! I slowly gave in to the thought that I'll have to add the air suspension upgrade which would be a really expensive upgrade just to park, not to mention the potential repair costs...
    I rechecked the technical sheet again today and realized that I'm a huge idiot. It actually says 22% which should be around 12.5 degrees. If the picture is an indication of the actual product I should be totally fine!
  8. EaglesPDX
    EaglesPDX Member
    PDX
    Breakover angle is just 6 degrees on the TS without air suspension. A shorter (by how much?) wheelbase on the T3 will increase that a little bit. This would apply if your driveway flattened out at the top.
