XPsionic
Here's a great video about the differences between the power split in track mode in snowy conditions.
TLDW: Even in 0/100 or 100/0 modes, when the steering is mostly pointed straight you still get AWD effects. Also traction control isn't completely unlimited even with stability set to -10%, and having regen set to more than 20% wasn't to the reviewer's liking on snow.
@tm1v2 I don't own a Performance, but my understanding is that the selectable torque split in track mode only applies under heavy cornering / slip angles. Even in track mode with 50/50 (or whatever) selected, your straight line torque delivery is still going to be heavily (mostly entirely) rear biased unless slippage occurs (as others have mentioned) or you're flooring the accelerator. It's not going to give you full time AWD with 50/50 torque split. Which makes sense, because otherwise if you toggle 100% to front or rear you'd be limiting total acceleration to the power available from one motor, and we know that doing that doesn't actually affect straight line acceleration.
